Synology RX1217SAS 12 Bay Rack Mountable
Quicklinx: FWJWWS00 Mfr#: RX1217SAS
Easily add 12 additional drive bays to Synology FlashStation or RackStation. Supporting both 2.5" and 3.5" SAS/SATA drives, the RX1217sas is a flexible solution supporting on-the-fly volume expansion or serving as a local backup destination. Dual power supplies ensure continuous service uptime. Easily replace defective drives with the hot-swappable drive trays.
  • 12-bay 3.5"/2.5" SAS/SATA expansion
  • Maximum reliability design
Synology RX1217sas - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
0 (installed) / 12 (max)
Supported Drives
SATA-600 / SAS
Hard Drive
No HDD
AC 120/230 V - 50 - 60 Hz
Power Redundancy
48.2 cm x 72.4 cm x 8.8 cm
18 kg
5-year warranty
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
12
Supported Drives
SATA-600 / SAS
CPU
No CPU
Hard Drive
No HDD
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" shared
1 x SAS (input) , 1 x SAS (output)
1 x mini SAS HD cable
FCC Class A certified, RoHS, BSMI Class A
2 x internal power supply
Max Supported Qty
2
Power Redundancy
48.2 cm
72.4 cm
8.8 cm
18 kg
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
