Synology RX1217RP 12 Bay 2U Rackmount NAS Expansion Enclosure
Quicklinx: CC51WS00 Mfr#: RX1217RP
Type: Storage enclosure
Controller Type: None
£1,403.43 ex VAT
£1,684.11 inc VAT
Synology Expansion Unit RX1217RP delivers an effortless solution for data volume expansion and data backup. With additional 12 drive bays, RX1217RP seamlessly expands the storage capacity of the connected Synology NAS on-the-fly.
  • Volume expansion and backup
    When running out of storage capacity, Synology RX1217RP provides an easy way to immediately scale capacity by additional 12 drives. The RAID volume on the Synology RackStation can be expanded directly without having to reformat the existing drives, ensuring the Synology RackStation continues its service during the capacity expansion. Synology RX1217RP can be used as a dedicated local backup solution for the Synology RackStation. When created as a separate volumeRX1217RP provides a great backup solution to its local drives in case of system failure.
  • Reliable plug-n-use design
    Synology 2U RackStation securely connects RX1217RP with a high-bandwidth expansion cable, that ensures maximum throughput. It allows the drives in the connected RX1217RP to operate as they are the internal ones of the Synology RackStation, with no lag in data retrieval. With SATA 6 Gb/s interface support, Synology RX1217RP unleashes the full performance of the installed drives and provides outstanding data transfer rate. To ensures 24/7 service uptime, Synology RX1217RP is equipped with redundant power supply units, allowing automatic fail-over support, if one of the PSUs is failed.
  • Green and easy to manage
    Deep Sleep can be manually configured to take effect automatically, when the system has been inactive for a period of time. This not only saves energy, but also extends the lifespan of the drives. RX1217RP also powers on/off with the attached RackStation, so no user intervention is needed to keep the system running smartly and efficiently.
Synology RX1217RP - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
0 (installed) / 12 (max)
Supported Drives
SATA-600
Hard Drive
No HDD
AC 120/230 V - 50/60 Hz
Power Redundancy
43.05 cm x 69.6 cm x 8.8 cm
13.4 kg
5-year warranty
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
12
Supported Drives
SATA-600
CPU
No CPU
Hard Drive
No HDD
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" shared
1 x InfiniBand
1 x InfiniBand cable
FCC Class A certified, RoHS, BSMI Class A
2 x internal power supply
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
43.05 cm
69.6 cm
8.8 cm
13.4 kg
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Brand: Synology
Price Range Ex VAT: £1000 - £1500
