Synology RX1217 12 Bay 2U Rackmout NAS Expansion Enclosure
Quicklinx: CC52WS00 Mfr#: RX1217
Type: Storage enclosure
Controller Type: None
£1,087.88 ex VAT
£1,305.45 inc VAT
When running out of storage capacity on the Synology 2U RackStation, Synology RX1217 provides an easy way to immediately scale capacity by additional 12 drives. The RAID volume on the Synology RackStation can be expanded directly without having to reformat the existing drives, ensuring the Synology RackStation continues its service during the capacity expansion. Synology RX1217 can be used as a dedicated local backup solution for the Synology RackStation. When created as a separate volume, RX1217 provides a great backup solution to its local drives in case of system failure.
Synology 2U RackStation securely connects to RX1217 with a high-bandwidth expansion cable that ensures maximum throughput. It allows the drives in the connected RX1217 to operate as they are the internal ones of the Synology RackStation, with no lag in data retrieval. With SATA 6Gb/s interface support, Synology RX1217 unleashes the full performance of the installed drives and provides outstanding data transfer rate.
Deep Sleep can be manually configured to take effect automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of the drives. RX1217 also powers on/off with the attached RackStation, so no user intervention is needed to keep the system running smartly and efficiently.
  • Volume expansion & backup
  • Reliable plug-n-use design
  • Green & easy to manage
Synology RX1217 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
0 (installed) / 12 (max)
Supported Drives
SATA-600
Hard Drive
No HDD
AC 120/230 V - 50/60 Hz
43.05 cm x 64.4 cm x 8.8 cm
12.7 kg
5-year warranty
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
12
Supported Drives
SATA-600
CPU
No CPU
Hard Drive
No HDD
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" shared
1 x InfiniBand
1 x InfiniBand cable
FCC Class A certified, RoHS, BSMI Class A
Internal power supply
43.05 cm
64.4 cm
8.8 cm
12.7 kg
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Brand: Synology
Price Range Ex VAT: £1000 - £1500
