Synology RX1216SAS 12 Bay Rack Expansion Unit
Quicklinx: BKBDWS00 Mfr#: RX1216SAS
Type: Hard drive array
Controller Type: RAID
£1,993.08 ex VAT
£2,391.69 inc VAT
Synology RX1216sas delivers an effortless storage capacity expansion solution for Synology RackStation RS18016xs+ by adding 12 drives on-the-fly while directly connected.
  • Robust scalability
    Designed to meet the demands of high data volume environments, the Synology RX1216sas supports up to 12 hot-swap drives, allowing for easy expansion and maintenance without system downtime.
  • High-speed performance
    With a data transfer rate of 600 MBps and support for Serial ATA-600 / SAS interfaces, this hard drive array ensures swift and reliable access to your data, enhancing overall system efficiency.
  • Enhanced reliability
    Featuring dual internal power supplies with a total power redundancy, the Synology RX1216sas ensures continuous operation, even in the event of a power supply failure, making it ideal for critical business applications.
  • Optimal operating conditions
    Operational within a wide range of temperatures (5°C to 35°C) and humidity (5 - 95%), ensuring reliable performance in various environmental conditions without compromising data integrity.
  • Compliance and standards
    Adheres to multiple compliance standards including BSMI Class A, BSMI Class B, FCC Class A certified, and RoHS, ensuring a high level of safety and reliability while being TAA-compliant for use in government and regulated industries.
Synology RX1216sas - hard drive array - TAA Compliant
Hard drive array
Enclosure Type
Rack-mountable
Max Supported Capacity
96 TB
SAS
0 (installed) / 12 (max)
Supported Drives
SATA-600 / SAS
Storage Controller
RAID (SATA 6Gb/s / SAS)
Hard Drive
No HDD - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
TAA Compliant
43 cm x 69.2 cm x 8.8 cm
13.5 kg
5-year warranty
Hard drive array
Enclosure Type
Rack-mountable
Chassis
0
Supported Devices / Modules Qty
12
Supported Drives
SATA-600 / SAS
Storage
96 TB
HDD Array External Interface
SAS
CPU
No CPU
Storage Controller
RAID
Channel Qty
12
Interface Type
SATA 6Gb/s / SAS
Data Transfer Rate
600 MBps
Hard Drive
No HDD - hot-swap
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" shared
2 x SAS (input) , 2 x SAS (output)
2 x SAS cable
FCC Class A certified, RoHS, BSMI Class B, BSMI Class A
TAA Compliant
2 x internal power supply
Max Supported Qty
2
Power Redundancy
67.31 Watt
Power Provided
500 Watt
43 cm
69.2 cm
8.8 cm
13.5 kg
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Sound Emission
45.1 dBA
Brand: Synology
Price Range Ex VAT: £1500+
