Synology RX1214 72TB (12 x 6TB RED PRO) 12 Bay NAS Solution
Quicklinx: BRSLWS00 Mfr#: RX1214/72TB-RED PRO
Synology RX1214 delivers an effortless solution for volume expansion and data backup for Synology RackStation. The RX1214 seamlessly scales up the storage capacity of the Synology RackStation by an additional 12 hard drives on-the-fly when connected directly to an expansion cable.
  • Volume expansion and backup
    When running out of hard drive capacity on the Synology RackStation, Synology RX1214 provides an easy way to immediately scale capacity by additional 12 hard drives. The RAID volume on the Synology RackStation can be expanded directly without having to reformat the existing hard drives, ensuring the Synology RackStation continues its service during the capacity expansion. Synology RX1214 can be used as a dedicated local backup solution for the Synology RackStation. When created as a separate volume, the Synology RX1214 provides a great backup solution to its local hard disks in case of system failure.
  • Reliable plug-n-use design
    Synology RackStation securely connects to Synology RX1214 with a high-bandwidth expansion cable that ensures maximum throughput. It allows the hard drives in the connected Synology RX1214 to operate as they are the internal ones of the Synology RackStation, with no lag in data retrieval. With SATA III 6 Gb/s interface support, Synology RX1214 unleashes the full performance of the installed drives and provides outstanding data transfer rate.
  • Easy to manage
    Deep sleep can be manually configured to take effect automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of the hard disk. The RX1214 will also smartly power on/off with the attached RackStation, so no user intervention is needed to keep this system running smartly and efficiently.
Synology RX1214 - storage enclosure - TAA Compliant
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
72 TB
12 (installed) / 12 (max)
Supported Drives
SATA-600
Hard Drive
12 x 6 TB HDD - hot-swap
AC 120/230 V - 50/60 Hz
TAA Compliant
44.5 cm x 57 cm x 8.8 cm
3-year warranty
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
12
Supported Devices / Modules Qty
12
Supported Drives
SATA-600
Storage
72 TB
CPU
No CPU
Hard Drive
HDD - hot-swap
12 x 6 TB
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
1 x InfiniBand
Built-in 4 cooling fans
1 x InfiniBand cable
FCC Class A certified, RoHS, BSMI Class A
TAA Compliant
Internal power supply
108 Watt
Power Provided
400 Watt
44.5 cm
57 cm
8.8 cm
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
40.5 dBA
