Synology RT2600ac Wireless router 4-port switch GigE
Quicklinx: CZJ7WS00 Mfr#: RT2600ac
Type: Wireless router
Connection Type: WAN/LAN
Standards: IEEE 802.11n, IEEE 802.11a, IEEE 802.11g, Fast Ethernet + 4 more
Speed: 2.53Gbps
Rackmount or External: Desktop
  • IEEE 802.11n
£146.13 ex VAT
£175.35 inc VAT
Blazing-fast Wi-Fi with up to 2.53 Gbps combined wireless bandwidth to supercharge your network. RT2600ac is a powerful wireless router for homes and small offices seeking to work and play smarter, featuring comprehensive VPN solutions, enhanced security, and flexible media and file sharing capabilities.
  • Engineered for performance
    Supporting MU-MIMO and the 802.11ac wave 2 standard, RT2600ac enables up to 800 Mbps and 1733 Mbps on the 2.4 GHz and 5 GHz radios respectively. Reach 2 Gbps combined bandwidth with Dual WAN, and easily optimize your network with minimal performance loss even with Layer 7 traffic control.
  • VPN Plus
    Keep your network's internal services and resources hardened against direct access while still allowing work from home or a remote location with VPNs. Easily deploy a wide range of VPN solutions and manage access permissions and bandwidth allowances.
  • Powerful connectivity management
    SRM delivers easy-to-use connectivity management tools to ensure your network always runs smoothly.
  • Smart WAN
    SRM's Smart WAN capability on the RT2600ac supports 2Gbps Dual WAN combined bandwidth when multiple connections are established. If one of the connections goes offline due to ISP or cable problems, traffic can failover to the other interface. Load balancing can be used in addition to failover, spreading traffic across both interfaces. Policy route allows traffic routing based on destination or source address.
  • Smart connect
    Not sure which devices should connect to the 2.4 GHz and 5 GHz bands? With Synology's smart connect, devices are connected to the most appropriate band automatically, letting users experience simplified management without worry about range or speed issues.
  • Intelligent web filtering and parental controls
    Instead of traditional URL-based web filtering, SRM does so during DNS lookup. Easily block out thousands of sites with built-in Google SafeSearch integration and a constantly updated database of customizable website categories.
  • Stay protected
    In addition to standard security tools like denial-of-service protection and firewall management, SRM delivers innovative tools and features to help protect your network from outside attacks.
Synology RT2600ac - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2.53 Gbps
Connection / user qty: 120
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DDNS
Routing Protocol
IGMP, static IP routing
Remote Management Protocol
SNMP, SSH
Firewall protection, DMZ port, DHCP support, NAT support, VPN support, WOL, IGMP snooping, DoS attack prevention, dynamic DNS server, manageable, print server, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, parental control, Access Point operational mode, firmware upgradable, download client, QoS, RADIUS support, SSH support, DHCP server, SMS alert, BitTorrent Client, Wireless Client Mode, DNS server, DLNA Media Server, port triggering, SPIF, eMule client, 3G/4G USB Dongle Support, Traffic Control, DHCP client, e-mail notification, 4T4R MIMO technology, VPN Server, SNMP support, WPS v2, beamforming technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
AC 100/230 V (50/60 Hz)
28 cm x 16.9 cm x 7.7 cm
700 g
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2.53 Gbps
Routing Protocol
SNMP, SSH
Encryption Algorithm
WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WEP
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac, FCC Class B certified, RoHS, BSMI Class B, NCC, iDA, RCM
1 x 1.7 GHz
RAM
512 MB DDR3 SDRAM
Status Indicators
Power, status, WAN, LAN
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A
Expansion Slots
1 SDXC
Aerial
Aerial
External detachable
Antenna Qty
4
Directivity
Omni-directional
External power adapter
10.8 Watt
1 x network cable
28 cm
16.9 cm
7.7 cm
700 g
5 °C
5 - 95%
Standards: IEEE 802.11a
Standards: IEEE 802.11g
Standards: Fast Ethernet
Standards: IEEE 802.11b
Standards: Gigabit Ethernet
Standards: Ethernet
Standards: IEEE 802.11ac
Speed: 2.53Gbps
Brand: Synology
