Synology RS820RP+ 4 Bay 1U Rack Mountable
Quicklinx: FFRKWS00 Mfr#: RS820RP+
Interface: Ethernet, Gigabit Ethernet, Fast Ethernet
Capacity: 0GB
  • Atom
£986.47 ex VAT
£1,183.76 inc VAT
Synology RackStation RS820RP+ is an ideal network-attached storage solution for centralizing data management. Powered by a 4-core processor, RS820RP+ provides both high performance and scalable storage, ideal for file sharing across different platforms and data backup.
  • Robust storage options
    With support for RAID 0, RAID 1, RAID 10, RAID 5, RAID 6, and JBOD, the Synology RackStation RS820RP+ offers a variety of storage configurations to meet diverse needs and ensure data redundancy and performance.
  • High-speed connectivity
    Equipped with four Ethernet 1000Base-T ports, two USB 3.0 ports, and one eSATA port, this NAS server provides multiple high-speed connectivity options for efficient data transfer and external storage expansion.
  • Advanced networking features
    Features such as Access Control List (ACL) support, Link Aggregation, and Wake On LAN (WOL) enhance network efficiency and security, making the RS820RP+ a reliable choice for managing network traffic and access.
  • Efficient performance
    Powered by an Intel Atom C3538 quad-core processor with a clock speed of 2.1 GHz and equipped with DDR4 SDRAM, the RS820RP+ delivers efficient and powerful performance for handling demanding storage tasks.
  • Versatile compatibility
    The RS820RP+ supports a wide range of network services and protocols, including Apple File Protocol (AFP), FTP, and WebDAV, ensuring seamless integration into existing network environments and easy access to stored data.
Synology RackStation RS820RP+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Max Supported Capacity
56 TB
0 (installed) / 4 (max)
43.05 cm x 45.76 cm x 4.4 cm
1 x Intel Atom C3538 2.1 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
40
RAM
2 GB
Storage Operating System
Synology DiskStation Manager
Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
0 GB
56 TB
43.05 cm
45.76 cm
4.4 cm
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
RAM
2 GB (installed) / 18 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DNS, POP3, IMAP, SMB, NFS, SFTP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH, SFTP, SMTP
Network Services Compatibility
Microsoft Active Directory (AD), DNS, File Level Security (ACLs), Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV), SFTP
Firewall protection, hardware encryption, LDAP support, WOL, antivirus analysis, backup server, download client, POP3 e-mail server, file sharing, event log, TFTP support, ACL support, RADIUS support, SSH support, iTunes server, FTP server, reset button, bandwidth control, surveillance station, PXE support, DNS server, DLNA Media Server, Apple Time Machine compatible, VPN Server, Dropbox support, Link Aggregation, Google Drive support, failover protection, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support, file station, hubiC support, OpenStack Swift-compatible, Baidu cloud support, cloud station server, Amazon S3 support, Alibaba Cloud OSS support, Backblaze B2 support, MegaDisk support
DLNA CERTIFIED
Security DVR
40
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x eSATA , 1 x serial (management) - DB-9
Internal power supply
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Hard Drives
FFRK Synology HAT5300-12T 12TB 3.5" SATA HDD In Stock £554.68
Interface: Ethernet
Interface: Gigabit Ethernet
Capacity: 0GB
Interface: Fast Ethernet
Brand: Synology
Price Range Ex VAT: £750 - £1000
