Powerful and scalable storage solution
Synology RackStation RS818+/RS818RP+ comes with a quad-core processor with the AES-NI hardware encryption engine, quad 1GbE LAN ports, and optional 10GbE NIC support. It provides both high performance and a scalable storage solution for sharing files across different platforms, centralizing data backups, and protecting critical assets.
Built for high service reliability
RS818+ comes with four 1Gbe LAB ports to supporrt Link Aggretion and failover. Synology High Availability support provides a reliable active/passive server cluster, keeping data and services online. Furthemore, RS818RP+ is equipped with redundant power supplies to deliver increased service continuty.
Real-time collaboration on your private cloud
Office is a collaboration package combining the convenience and usability of public clouds with the data privacy and security guaranteed by private clouds. It allows you to work seamlessly together on documents and spreadsheets in a protected environment.
Fully certified storage virtualization solutions
Synology iSCSI storage fully supports most virtualization solutions to enhance work efficiency with easy management interface. VMware vSphere 6 and VAAI integration helps offload storage operations and optimizes computation efficiency. Windows Offloaded Data Transfer (ODX) speeds up data transfer and migration rate. OpenStack Cinder support turns your Synology NAS into a block-based storage component.
12TB (4 x 3TB) WD Red Hard Drive included!
The server comes with four 1 GbE LAN ports to support Link Aggregation and failover. Synology High Availability support provides a reliable active/passive server cluster, keeping data and services online. -
Office is a collaboration package combining the convenience and usability of public clouds with the data privacy and security guaranteed by private clouds. It allows you to work seamlessly together on documents and spreadsheets in a protected environment. -
Empower your storage with speedier performance
The server allows network and memory upgrades to boost system performance.
- Synology RackStation RS818RP+ - NAS server - 12 TB - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 1U
- Total Storage Capacity
- 12 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 48 cm x 51.86 cm x 4.4 cm
- Processor
- 1 x Intel Atom C2538 2.4 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
- Hard Drive
- 4 x 3 TB
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 40
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
- TAA Compliant
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- 12 TB
- 48 cm
- 51.86 cm
- 4.4 cm
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- RAM
- 2 GB (installed) / 16 GB (supported) - DDR3L
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Hard Drive
- HDD
- Capacity
- 4 x 3 TB
- Data Link Protocol
- PPTP, L2TP, FTP
- Remote Management Protocol
- SNMP, Telnet, HTTP
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Hardware encryption, VPN support, LDAP support, wake on LAN (WOL), Syslog support, High Availability, web server, backup server, download client, Access Control List (ACL) support, RADIUS support, SSH support, iTunes server, FTP server, bandwidth control, surveillance station, VPN Server, anti-virus protection, scheduler, file station, Windows ODX, cloud station server, MailPlus server
- Encryption Algorithm
- AES-NI
- DLNA CERTIFIED
Security DVR
- 40
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCI Express x8
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x eSATA , 1 x serial (management) - DB-9
- Wake on LAN, built-in 2 cooling fans
- FCC Class A certified, VCCI, CCC, RoHS, BSMI Class A, KC, EAC, RCM
- TAA Compliant
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 45.73 Watt
- Power Provided
- 150 Watt
- OS Required
- TAA Compliant
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 32.7 dBA
