RS4017xs+ provides rock-solid storage solution with ultra-high performance at over 690,000 sequential read IOPS and 4,900 MB/s sequential read throughput. DDR4 ECC UDIMM and 10 GbE connectivity guarantees data accuracy and performance for mission-critical environment.
High availability
Ensures seamless transition between clustered servers in the event of server failure with minimal impact to applications. -
Hyper backup
Minimize storage space required for backing up data in multiple versions with block-level incremental backup and cross-version deduplication. -
Cloud station suite
Automatic cross-platform data synchronization with file version control. -
CMS
Manage multiple Synology NAS servers simultaneously through a centralized interface to increase administrative efficiency and flexibility. -
MailPlus
Set up a secure, reliable and private mail server with stylish and intuitive user interface. -
Collaboration suite
Synology Office, Calendar and Chat guarantee a secure and high-performance private communication and user-friendly content organization.
- Synology RackStation RS4017XS+ - NAS server - 160 TB
- NAS server
- Host Connectivity
- 10GBase-T
- Enclosure Type
- Rack-mountable - 3U
- Total Storage Capacity
- 160 TB
- Installed Devices / Modules Qty
- 16 (installed) / 16 (max)
- 48.2 cm x 65.65 cm x 13.23 cm
- 17.4 kg ()
- Processor
- 1 x Intel Xeon D-1541 2.1 GHz (8-core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 16 x 10 TB
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE, 10GbE
- IP Cameras Supported
- 90
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- System Requirements
- Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
- 5-year warranty
- NAS server
- Host Connectivity
- 10GBase-T
- Enclosure Type
- 160 TB
- 48.2 cm
- 65.65 cm
- 13.23 cm
- 17.4 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- 8-core
- Max Supported Qty
- 1
- Max Turbo Speed
- 2.7 GHz
- RAM
- 8 GB (installed) / 64 GB (supported) - DDR4
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD
- Capacity
- 16 x 10 TB
- Data Link Protocol
- PPTP, L2TP, iSCSI
- Remote Management Protocol
- SNMP, Telnet, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, VPN support, wake on LAN (WOL), Syslog support, Access Control List (ACL) support, 3 fans, Link Aggregation, scheduler, failover protection, OpenStack compatible
- Encryption Algorithm
- SSL, TLS, AES-NI
- DLNA CERTIFIED
Security DVR
- 90
- Expansion Bays
- 16 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 4 (total) / 3 (free) x DIMM 288-pin ¦ 2 (total) / 2 (free) x PCI Express 3.0 x8
- 4 x Ethernet 1000Base-T - RJ-45 ¦ 2 x USB 3.0 ¦ 2 x Ethernet 10Gb - RJ-45 ¦ 1 x serial - DB-9 ¦ 2 x InfiniBand
- Citrix Ready, VMware Ready
- FCC Class A certified, RoHS, BSMI Class A
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 136.4 Watt
- OS Required
- Limited warranty - 5 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 44.7 dBA
