Synology RS3621RPxs 12 Bay Rackmount Enclosure
Quicklinx: G594WS00 Mfr#: RS3621RPXS
Type: Rackmount Kit
Controller Type: RAID
  • Xeon
£2,756.49 ex VAT
£3,307.78 inc VAT
Synology RS3621RPxs is a powerful 12-bay storage server. Its 6-core processor enables compute-intensive services while its redundant power, ECC memory, and Btrfs file system safeguard mission-critical data. Capable of delivering 189,098 4K random read IOPS and 4,718 MB/s sequential read throughput, it is ideal for small businesses.
  • Redundant power
    Dual PSUs provide protection against a PSU failure or accidental cord removal while hot-swappable fans can be replaced without powering down the system.
  • Near-zero downtime
    Synology High Availability (SHA) pairs two identical units together creating an active-passive cluster with minute-level failover.
  • Next-generation file system
    Btrfs prevents data corruption and reduces maintenance overheads with advanced storage technologies and optimized snapshots.
  • Customize to suit
    The two built-in PCIe slots allow users to customize RS3621RPxs to satisfy unique performance, networking, and storage requirements.
Synology RackStation RS3621RPxs - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
0 (installed) / 12 (max)
48.2 cm x 72.4 cm x 8.8 cm
14.5 kg ()
1 x Intel Xeon D-1531 2.2 GHz (6-core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, RAID F1, 1 hot spare, 10 hot spare, 5 hot spare, 6 hot spare, F1 hot spare
1GbE
RAM
8 GB
Power Redundancy
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
48.2 cm
72.4 cm
8.8 cm
14.5 kg ()
Processor / Memory
Processors Installed
Number of Cores
6-core
Max Supported Qty
1
Max Turbo Speed
2.7 GHz
RAM
8 GB (installed) / 64 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1, RAID 1 hot spare, RAID 10 hot spare, RAID 5 hot spare, RAID 6 hot spare, RAID F1 hot spare
1GbE
Network / Transport Protocol
PPTP, L2TP, iSCSI, SMTP, FTP, DHCP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, VPN support, LDAP support, VLAN support, WOL, print server, antivirus analysis, High Availability, web server, backup server, file sharing, event log, ACL support, iTunes server, DHCP server, FTP server, BitTorrent Client, e-mail server, bandwidth control, surveillance station, eMule client, e-mail notification
Encryption Algorithm
256-bit AES
DLNA CERTIFIED
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 2 (free) x PCI Express 3.0 x8 , 4 (total) / 3 (free) x DIMM 288-pin
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.2 Gen 1 - Type A , 2 x expansion port , 1 x management
FCC, BSMI, VCCI, RCM, EAC, CCC, KC, UL, RoHS
Accessory pack
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
140.01 Watt
Power Provided
500 Watt
Limited warranty - 5 years
35 °C
5 - 95%
Sound Emission
50.2 dBA
Hard Drives
G594 Synology HAT5300-12T 12TB 3.5" SATA HDD In Stock £589.34
Type: Rackmount Kit
Brand: Synology
Price Range Ex VAT: £1500+
