Synology RackStation (RS3618XS)
The Synology (RS3618XS) is a reliable, superior-performance network-attached storage solution for large-scale enterprises with demanding business applications. It simplifies data management, optimises virtualisation environments, and rapidly expands storage capacity with minimal time investment in setup and maintenance.
Synology (RS3618XS) Key Features
- High-speed Scalable Storage Server
- Btrfs: Next Generation Storage Efficiency
- Comprehensive Business Applications
- Running on Synology DiskStation Manager (DSM)
- Reliable centralised storage solution for large scale businesses
- Quad-core CPU with AES-NI and 8GB (up to 64GB) DDR4 ECC UDIMM
- Ultra-high performance of over 3,900 MB/s sequential reading and 143,500 iSCSI random read IOPS1 , capable of installing optional 10GbE/40GbE NICs
- Scalable up to 36 drives with Synology RX1217/RX1217RP2
- Complete virtualisation solution with Synology Virtual Machine Manager
- Dynamic iSCSI/NFS storage for VMware, Windows Hyper-V, Citrix, and OpenStack
- Synology RS3618xs is a 2U 12-bay rackmount network-attached storage solution equipped with a quad-core processor and 8GB DDR4 memory (expandable up to 64GB), meeting the needs for large-scale businesses. With 10GbE Link Aggregation enabled, RS3618xs delivers great performance at over 3,900 MB/s sequential reading throughput and 143,500 iSCSI random IOPS under a RAID 5 configuration. Encrypted data throughput can reach over 2,300 MB/s in reading and 1,177 MB/s in writing. RS3618xs provides great flexibility to easily scale up to 36 drives when connected to two Synology RX1217 or RX1217RP expansion units. Storage capacity can be expanded according to your business needs with minimal effort.
Ready for 10GbE and beyond
PCIe 3.0 slots allow for faster networking options as you expand your infrastructure. Together with the built-in quad Gigabit ports, RS3618xs offers comprehensive connectivity options for link aggregation and failover configurations. -
Fully certified storage virtualization solutions
Synology iSCSI storage fully supports most virtualization solutions to enhance work efficiency with easy management interface. -
Next-generation file system for better data protection
The Btrfs file system introduces advanced storage technologies and optimized snapshots to prevent data corruption and reduce maintenance overhead. While ensuring high-level data integrity, it also offers flexible, efficient data protection and recovery tools. -
Ultimate backup solution
RS3618xs integrates various backup applications into an intuitive user interface, offering durable storage technologies to safeguard your valuable data on any device.
- Synology RackStation RS3618XS - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- 43.05 cm x 69.2 cm x 8.8 cm
- Processor
- 1 x Intel Xeon D-1521 2.4 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, RAID F1
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 43.05 cm
- 69.2 cm
- 8.8 cm
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- Max Turbo Speed
- 2.7 GHz
- RAM
- 8 GB (installed) / 64 GB (supported) - DDR4
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1
- Data Link Protocol
- L2TP, iSCSI
- Remote Management Protocol
- SNMP, Telnet, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, LDAP support, WOL, antivirus analysis, ACL support, iTunes server, UPnP Media Server, surveillance station, DLNA Media Server, cloud backup, VPN Server
- Encryption Algorithm
- AES, SSL, TLS
- DLNA CERTIFIED
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 2 (free) x PCI Express x8
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A
- Wake on LAN, built-in 4 cooling fans
- FCC Class A certified, RoHS, BSMI Class A
- Power Device
- Internal power supply
- Installed Qty
- 1
- Max Supported Qty
- 1
- Voltage Required
- Power Provided
- 500 Watt
- 5 °C
- 35 °C
- 5 - 95%
Hard Drives
Synology HAT5300-12T 12TB 3.5" SATA HDD | In Stock | £433.22 |
