Synology RS3617RPxs 12 Bay Rack Mountable
Quicklinx: FWJVWS00 Mfr#: RS3617RPXS
  • Xeon
Designed for businesses seeking large data storage capacity, RS3617RPxs is a high-performance, 12-bay rackmount NAS equipped with redundant power supplies, ensuring business continuity. Organizations can integrate seamlessly with virtualization solutions.
  • High-performance NAS server
    RS3617RPxs delivers stunning performance. Equipped with DDR4 ECC RAM, RS3617RPxs ensures data accuracy when handling high-value data and mission-critical tasks across large-scale businesses.
  • Scale on demand
    As your data storage needs grow, RS3617RPxs can be connected to one or two dedicated expansion units, allowing you to expand storage capacity without disrupting service. The high-bandwidth cable ensures speedy data transmission between the main server and expansion unit.
  • 10GbE network capability
    In addition to the four built-in Gigabit ports, RS3617RPxs comes with two PCIe 3.0 x8 slots that allow for the installation of two 10GbE network interface cards, maximizing bandwidth and meeting high-performance requirements for data-intensive applications.
  • Reliable redundancy mechanisms
    RS3617RPxs comes with comprehensive redundancy mechanisms to ensure business continuity. Built-in four LAN ports with failover provide reliable redundancy in the event of unexpected network failure. The high reliability system design, including fanless CPU heat-sink and passive cooling technologies, prevents a single point of failure. Other features such as redundant power supplies, system fans, and network ports with failover support ensure continual service uptime.
  • Enhanced encryption performance
    RS3617RPxs is equipped with an encryption engine which offloads encryption calculation tasks from the main CPU, thus allowing it to perform other important tasks. In addition, Advanced Encryption Standard (AES) on shared folders with hardware acceleration ensures security without compromising access performance.
  • SSD cache technology
    RS3617RPxs enables the combination of hard drives and read/write-optimized SSD cache, boosting throughput efficiently while minimizing cost per gigabyte. With full SSD cache reading and writing support, RS3617RPxs offers a significant reduction in I/O latency without crippling your budget. With only a small upfront investment, businesses can benefit from significant server performance enhancement.
Synology RackStation RS3617RPxs - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
144 TB
0 (installed) / 12 (max)
69.2 cm x 43.05 cm x 8.8 cm
14.5 kg ()
1 x Intel Xeon D-1521 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
75
RAM
8 GB
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
144 TB
69.2 cm
43.05 cm
8.8 cm
14.5 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
8 GB (installed) / 64 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
L2TP, iSCSI
Remote Management Protocol
SNMP, Telnet, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, WOL, antivirus analysis, ACL support, iTunes server, UPnP Media Server, surveillance station, DLNA Media Server, cloud backup, VPN Server
Encryption Algorithm
AES, SSL, TLS
DLNA CERTIFIED
Security DVR
75
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 2 (free) x PCI Express 3.0 x8
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9 , 2 x InfiniBand
FCC Class A certified, RoHS, BSMI Class A
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Provided
500 watt
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
