Synology RS2821RP+ 16 Bay Rackmount NAS
Quicklinx: G9Z8WS00 Mfr#: RS2821RP+
Type: Rackmount Kit
Controller Type: RAID
Hurry, only 1 left in stock!
£2,664.72 ex VAT
£3,197.66 inc VAT
Synology RS2821RP+ is a 3U 16-bay storage server designed to accommodate a diverse set of business requirements. Scalable to 28 drives, the unit provides powerful backup and restoration functionality for the SMB sector. It delivers 2,200 MB/s sequential read and 105K 4K random read performance.
  • High performance storage for anything
    Over 105K/59K random read/write IOPS and up to 2,220/1,164 MB/s sequential read/write throughput ensure ample performance for demanding workloads.
  • Redundant power
    Reduce the possibility of power disruptions on a single distribution channel or PDU adversely impacting data and service availability.
  • Near-zero downtime
    Pair two identical devices with Synology High Availability and enable automatic minute-level failover between both devices in the event one server fails.
  • Data integrity and protection
    ECC memory prevents data corruption, while the Btrfs file system brings higher reliability, snapshot technology, and simplified data protection.
  • Customize to suit
    Easily adapt the RS2821RP+ to any business environment by adding faster networking, local SSD cache, or storage capacity.
  • Hyper backup
    Back up files, iSCSI LUNs, installed applications, and system configurations to destinations including Synology C2 Storage, public cloud platforms, USB devices, file servers, local folders, or other Synology NAS. Set and forget backup tasks with regular schedules, enhance security with fine-grained user permissions and encryption, keep backup sizes small with built-in deduplication, and restore data flexibly with multi-versioning.
  • Snapshot Replication
    Snapshot Replication enables flexible point-in-time snapshots of shared folders, and virtual machines with an RPO as low as 5 minutes and recovery within seconds.
  • Serving remote workforces
    Keep your remote workforce connected with powerful out-of-the-box solutions for collaboration, file sharing, and communication.
Synology RackStation RS2821RP+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 3U
Max Supported Capacity
108 TB
0 (installed) / 16 (max)
48.2 cm x 65.65 cm x 13.23 cm
17.1 kg ()
1 x Ryzen Embedded V1500B 2.2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
40
RAM
4 GB
Power Redundancy
Microsoft Windows 7, Apple macOS 10.12
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 3U
Total Storage Capacity
0 GB
108 TB
48.2 cm
65.65 cm
13.23 cm
17.1 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 32 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
PPTP, L2TP, iSCSI, FTP, SMB, NFS, SFTP, HTTPs
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH, SFTP
Network Services Compatibility
Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV), SFTP
VPN support, LDAP support, WOL, ACL support, SSH support, e-mail server, reset button, Rsync compatible, L2TP support
Encryption Algorithm
SSL, TLS, AES-NI
Security DVR
40
Expansion Bays
16 (total) / 16 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express
4 x Ethernet 1000Base-T , 2 x USB 3.2 - Type A , 1 x management
Built-in 3 cooling fans
UL, VCCI, BSMI, CCC, FCC, RoHS, KC, EAC, RCM, TLS, SSL
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Limited warranty - 3 years
35 °C
5 - 95%
Sound Emission
53.5 dBA
G9Z8 Synology DDR4 - module - 4 GB for RS2421+, RS2421RP+, RS2821RP+ In Stock £176.97
Type: Rackmount Kit
Brand: Synology
Price Range Ex VAT: £1500+
