Synology RS2821RP+ is a 3U 16-bay storage server designed to accommodate a diverse set of business requirements. Scalable to 28 drives, the unit provides powerful backup and restoration functionality for the SMB sector. It delivers 2,200 MB/s sequential read and 105K 4K random read performance.
High performance storage for anything
Over 105K/59K random read/write IOPS and up to 2,220/1,164 MB/s sequential read/write throughput ensure ample performance for demanding workloads. -
Redundant power
Reduce the possibility of power disruptions on a single distribution channel or PDU adversely impacting data and service availability. -
Near-zero downtime
Pair two identical devices with Synology High Availability and enable automatic minute-level failover between both devices in the event one server fails. -
Data integrity and protection
ECC memory prevents data corruption, while the Btrfs file system brings higher reliability, snapshot technology, and simplified data protection. -
Customize to suit
Easily adapt the RS2821RP+ to any business environment by adding faster networking, local SSD cache, or storage capacity. -
Hyper backup
Back up files, iSCSI LUNs, installed applications, and system configurations to destinations including Synology C2 Storage, public cloud platforms, USB devices, file servers, local folders, or other Synology NAS. Set and forget backup tasks with regular schedules, enhance security with fine-grained user permissions and encryption, keep backup sizes small with built-in deduplication, and restore data flexibly with multi-versioning. -
Snapshot Replication
Snapshot Replication enables flexible point-in-time snapshots of shared folders, and virtual machines with an RPO as low as 5 minutes and recovery within seconds. -
Serving remote workforces
Keep your remote workforce connected with powerful out-of-the-box solutions for collaboration, file sharing, and communication.
- Synology RackStation RS2821RP+ - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 3U
- Max Supported Capacity
- 108 TB
- Installed Devices / Modules Qty
- 0 (installed) / 16 (max)
- 48.2 cm x 65.65 cm x 13.23 cm
- 17.1 kg ()
- Processor
- 1 x Ryzen Embedded V1500B 2.2 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 40
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- System Requirements
- Microsoft Windows 7, Apple macOS 10.12
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 108 TB
- 48.2 cm
- 65.65 cm
- 13.23 cm
- 17.1 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 4 GB (installed) / 32 GB (supported) - DDR4
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
- Data Link Protocol
- PPTP, L2TP, iSCSI, FTP, SMB, NFS, SFTP, HTTPs
- Remote Management Protocol
- SNMP, Telnet, HTTPS, SSH, SFTP
- Network Services Compatibility
- Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV), SFTP
- VPN support, LDAP support, WOL, ACL support, SSH support, e-mail server, reset button, Rsync compatible, L2TP support
- Encryption Algorithm
- SSL, TLS, AES-NI
Security DVR
- 40
- Expansion Bays
- 16 (total) / 16 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 1 (total) / 1 (free) x PCI Express
- 4 x Ethernet 1000Base-T , 2 x USB 3.2 - Type A , 1 x management
- Built-in 3 cooling fans
- UL, VCCI, BSMI, CCC, FCC, RoHS, KC, EAC, RCM, TLS, SSL
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- OS Required
- Limited warranty - 3 years
- 0 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 53.5 dBA
Synology DDR4 - module - 4 GB for RS2421+, RS2421RP+, RS2821RP+ | In Stock | £52.46 |
