Snapshots preserve the history of a shared folder allowing you to save up to 2561 backup copies for point-in-time recovery. Snapshots can be automatically captured up to every 5 minutes, without noticeably impacting system performance.
Btrfs file system stores two copies of critical metadata on a volume, improving the availability and survivability of your business's important data. By generating checksums for files and metadata, the system can automatically detect and attempt to repair corrupted data or report errors to the administrator.
Fast and efficient snapshots
Snapshots preserve the history of a shared folder allowing you to save up to 2561 backup copies for point-in-time recovery. Snapshots can be automatically captured up to every 5 minutes, without noticeably impacting system performance. -
Metadata mirroring and survivability
Btrfs file system stores two copies of critical metadata on a volume, improving the availability and survivability of your business's important data. -
Corruption detection and correction
By generating checksums for files and metadata, the system can automatically detect and attempt to repair corrupted data or report errors to the administrator. -
Customizable quotas for shared folders
With Btrfs, you can specify a storage limit for each shared folder, making it possible to precisely control space consumption when multiple teams or departments save files on the same Synology NAS server. -
Speedy data encryption with AES-NI
As businesses store more and more critical information in digital form, data encryption has become an essential aspect of any healthy security policy. Equipped with a dedicated AES-NI hardware encryption engine, RS2416RP+ delivers encrypted data transmission speeds over 399 MB/s reading and 198 MB/s writing, making it the ideal digital locker for your sensitive data. -
Redundancy mechanisms for higher uptime
RS2416RP+ includes redundant hardware mechanisms to ensure business continuity. The four built-in Ethernet ports with Link Aggregation and failover provide reliability in the event of unexpected hardware failure, while the hot-swappable drives to minimize system downtime during drive replacement. Redundant power supply units minimizes the chance of a complete system shutdown due to sudden power loss.
- Synology RackStation RS2416RP+ - NAS server - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Max Supported Capacity
- 96 TB
- Installed Devices / Modules Qty
- 0 (installed) / 12 (max)
- 43 cm x 69.2 cm x 8.8 cm
- 13.24 kg ()
- Processor
- 1 x Atom C2358 1.7 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 40
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- TAA Compliant
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 96 TB
- 43 cm
- 69.2 cm
- 8.8 cm
- 13.24 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 2 GB (installed) / 6 GB (supported) - DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
- Data Link Protocol
- L2TP, iSCSI, FTP
- Remote Management Protocol
- SNMP, Telnet
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Calendaring Extensions to WebDAV (CalDAV)
- LDAP support, wake on LAN (WOL), Syslog support, antivirus analysis, video server, Access Control List (ACL) support, e-mail server, surveillance station, cloud backup, VPN Server
- Encryption Algorithm
- SSL, TLS
Security DVR
- 40
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 4 x Ethernet 1000Base-T , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x management
- Built-in 4 cooling fans
- RoHS
- TAA Compliant
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- Power Provided
- 500 Watt
- OS Required
- TAA Compliant
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 44.3 dBA
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
