Synology RS1619xs+ 4 Bay Rackmount NAS
Quicklinx: DZPHWS00 Mfr#: RS1619XS+
Type: NAS server
Controller Type: Serial ATA
  • Xeon
Hurry, only 2 left in stock!
£1,650.12 ex VAT
£1,980.14 inc VAT
RS1619xs+ is a high-performance and scalable 1U rackmount NAS designed with upgradable memory and M.2 SSD cache configuration to meet the needs of modern businesses that require a flexible, reliable, and efficient storage solution.
  • Robust security
    Equipped with AES-NI, SSL, and TLS encryption algorithms, the Synology RackStation RS1619xs+ ensures your data remains secure and protected. Its comprehensive security features, including anti-malware and anti-virus protection, safeguard your system against potential threats.
  • High-performance storage
    Featuring a quad-core Intel Xeon processor with a clock speed of 2.2 GHz and turbo up to 2.7 GHz, along with DDR4 ECC RAM, the RS1619xs+ delivers exceptional performance for your storage needs. Its support for RAID configurations enhances data protection and reliability.
  • Versatile connectivity
    With four Gigabit Ethernet ports, two USB-A ports, and expansion slots including PCI Express 3.0 x8 and M.2, the RS1619xs+ offers flexible connectivity options for various networking and storage expansion needs.
  • Comprehensive network services
    The RS1619xs+ supports a wide range of network protocols and services, including FTP, NFS, iSCSI, and WebDAV, making it a versatile choice for managing and sharing files across different platforms and devices.
  • Advanced surveillance capabilities
    Supporting up to 75 IP cameras and featuring H.264, H.265, and MJPEG compression formats, the RS1619xs+ serves as a powerful surveillance station, providing high-quality video monitoring and recording capabilities.
Synology RackStation RS1619xs+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Max Supported Capacity
56 TB
0 (installed) / 4 (max)
48 cm x 51.86 cm x 4.4 cm
8.16 kg ()
1 x Intel Xeon D-1527 2.2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, RAID F1
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
75
RAM
8 GB
Power Redundancy
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
0 GB
56 TB
48 cm
51.86 cm
4.4 cm
8.16 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.7 GHz
RAM
8 GB (installed) / 64 GB (supported) - DDR4
ECC
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, FTP, NFS
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, LDAP support, WOL, IP address filtering, backup server, download client, anti-malware protection, event log, ACL support, Samba support, FTP server, reset button, bandwidth control, surveillance station, PXE support, DLNA Media Server, cloud backup, VPN Server, Dropbox support, anti-virus protection, Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support, hubiC support, OpenStack Swift-compatible, cloud station server, MailPlus server, Amazon S3 support
Encryption Algorithm
SSL, TLS, AES-NI
DLNA CERTIFIED
Security DVR
75
Compression Format
MJPEG, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x8 , 4 (total) / 3 (free) x DIMM 288-pin , 2 (total) / 2 (free) x M.2
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x serial (management) - DB-9
Wake on LAN, built-in 2 cooling fans, scheduled power on/off
VCCI, BSMI, CCC, FCC, RoHS, KC, EAC, RCM
Accessory pack
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
68.68 Watt
Power Provided
150 Watt
Software Included
McAfee AntiVirus (Trial)
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Sound Emission
39.3 dBA
Hard Drives
DZPH Synology HAT5300-12T 12TB 3.5" SATA HDD In Stock £433.22
DZPH Synology 8TB HAS5300 3.5" SAS Hard Drive In Stock £247.38
Type: NAS server
Brand: Synology
Price Range Ex VAT: £1500+
