Synology RS1219+/48TB-EXOS 8 Bay Rackmount NAS
Quicklinx: DRWFWS00 Mfr#: RS1219+/48TB-EXOS
  • Atom
Marketing description is not available.
  • Robust storage capacity
    Equipped with 8 hot-swap expansion bays, the Synology RackStation RS1219+ offers flexible storage options supporting both 2.5" and 3.5" drives. This design allows for easy maintenance and expansion, ensuring your data storage can grow with your needs.
  • High-performance networking
    Featuring four Ethernet 1000Base-T ports, two USB 3.0 ports, and one eSATA port, the RS1219+ provides versatile connectivity options. With support for Gigabit Ethernet, this RackStation ensures high-speed data transfer rates, making it suitable for handling intensive data exchange environments.
  • Advanced security features
    The RS1219+ is equipped with SSL and TLS encryption algorithms, enhancing data security. With built-in support for VPN Server, antivirus analysis, and Access Control List (ACL), it offers comprehensive tools to protect your data from unauthorized access and threats.
  • Efficient cooling system
    Designed with built-in 2 cooling fans, the RS1219+ maintains optimal operating temperatures, ensuring reliable performance and longevity of the device. This feature is crucial for maintaining system stability in rack-mounted environments.
  • Comprehensive surveillance solution
    Supporting up to 40 IP cameras, the RS1219+ serves as a powerful surveillance station. It offers extensive features such as video server capabilities, cloud backup, and Wake On LAN (WOL), making it a suitable choice for businesses looking to enhance their security infrastructure.
Synology RackStation RS1219+ - NAS server - 48 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
48 TB
Max Supported Capacity
108 TB
8 (installed) / 8 (max)
48.19 cm x 30.66 cm x 8.8 cm
6.9 kg ()
1 x Atom C2538 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
8 x 6 TB
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
40
RAM
2 GB
Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
48 TB
108 TB
48.19 cm
30.66 cm
8.8 cm
6.9 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB (installed) / 16 GB (supported) - DDR3L
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD
8 x 6 TB
Network / Transport Protocol
PPTP, L2TP, iSCSI, FTP, NFS
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
LDAP support, wake on LAN (WOL), Syslog support, antivirus analysis, video server, Access Control List (ACL) support, e-mail server, surveillance station, cloud backup, VPN Server
Encryption Algorithm
SSL, TLS
Security DVR
40
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 2.0 x8
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x eSATA
Built-in 2 cooling fans
RoHS
Accessory pack
Internal power supply
Installed Qty
1
Max Supported Qty
1
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
