Synology RAM1600DDR3L-8GBx2 16GB Kit (8GB x 2) DDR3L-1600 un
Quicklinx: DD7DWS00 Mfr#: RAM1600DDR3L-8GBX2
Type: DDR3L SDRAM
Capacity: 16GB
Connection: SO-DIMM 204-pin
Speed: 1600MHz
Data Integrity: Non-ECC
£228.13 ex VAT
£273.75 inc VAT
Marketing description is not available.
  • Enhanced compatibility
    Designed specifically for PCs, this memory kit ensures seamless integration with your system, providing a reliable upgrade solution.
  • Efficient performance
    With a memory speed of 1600 MHz and low voltage technology, this DDR3L SDRAM kit enhances your system's performance while ensuring energy efficiency.
  • Easy upgrade
    The unbuffered, non-ECC feature of this 2-module kit allows for a straightforward installation, making it an ideal choice for system-specific upgrades.
Synology - DDR3L - kit - 16 GB: 2 x 8 GB - SO-DIMM 204-pin - 1600 MHz / PC3L-12800 - unbuffered
Memory kit
16 GB: 2 x 8 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Low Voltage, unbuffered
Voltage
1.35 V
Disk Station DS1517+, DS1817+
16 GB: 2 x 8 GB
Upgrade Type
System specific
DRAM memory kit
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Voltage
1.35 V
Synology Disk Station DS1517+, DS1817+
Type: DDR3L SDRAM
Capacity: 16GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
Standard: PC3L-12800
Brand: Synology
