Synology RackStation RS819 2GB 4-bay NAS
Quicklinx: F56HWS00 Mfr#: RS819
Interface: Ethernet, Gigabit Ethernet, Fast Ethernet
Capacity: 0GB
£491.97 ex VAT
£590.36 inc VAT
RS819 is a compact and scalable 4-bay rackmount NAS in a 1U form factor. With snapshot technology support, RS819 brings business workgroups simple yet comprehensive solutions to data management, sharing, synchronization and backup.
  • Robust storage options
    With support for RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, and JBOD, the Synology RackStation RS819 offers a range of storage configurations to meet diverse needs, ensuring data redundancy and performance optimization.
  • Comprehensive network compatibility
    Featuring Gigabit Ethernet connectivity and supporting a variety of network protocols including DNS, FTP, NFS, SMB, and iSCSI, the RS819 ensures seamless integration into any network environment, enhancing file sharing and accessibility.
  • Advanced security features
    Equipped with SSL and TLS encryption algorithms, alongside hardware encryption, firewall protection, and antivirus analysis, the RS819 provides a secure data storage solution, safeguarding sensitive information against unauthorized access.
  • Versatile media and cloud support
    The RS819 excels in media and cloud integration, offering support for DLNA Media Server, iTunes server, and various cloud storage services like Amazon S3, Google Drive, and Dropbox, enabling efficient data backup and sharing.
  • High-definition surveillance capability
    Supporting up to 30 IP cameras and featuring H.264, H.265, and MJPEG compression formats, the RS819 serves as a robust surveillance solution, providing high-quality video monitoring and recording capabilities.
Synology RackStation RS819 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Max Supported Capacity
56 TB
0 (installed) / 4 (max)
43.05 cm x 29.55 cm x 4.4 cm
4.34 kg ()
1 x Realtek Semiconductor RTD1296 1.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
30
RAM
2 GB
Storage Operating System
Synology DiskStation Manager
Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
0 GB
56 TB
43.05 cm
29.55 cm
4.4 cm
4.34 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DNS, POP3, IMAP, SMB, NFS, SFTP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH, SFTP, SMTP
Network Services Compatibility
Microsoft Active Directory (AD), DNS, File Level Security (ACLs), Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV), SFTP
Firewall protection, hardware encryption, LDAP support, WOL, antivirus analysis, backup server, download client, POP3 e-mail server, file sharing, event log, TFTP support, ACL support, RADIUS support, SSH support, iTunes server, FTP server, reset button, bandwidth control, surveillance station, PXE support, DNS server, DLNA Media Server, Apple Time Machine compatible, VPN Server, Dropbox support, Link Aggregation, Google Drive support, failover protection, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support, file station, hubiC support, OpenStack Swift-compatible, Baidu cloud support, cloud station server, Amazon S3 support, Alibaba Cloud OSS support, Backblaze B2 support, MegaDisk support
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED
Security DVR
30
Compression Format
MJPEG, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x eSATA , 1 x serial (management) - DB-9
Audible alarm, wake on LAN, built-in 3 cooling fans, scheduled power on/off
VCCI, BSMI, CCC, FCC, RoHS, EAC, RCM
Accessory pack
Internal power supply
Power Provided
150 Watt
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Interface: Ethernet
Interface: Gigabit Ethernet
Interface: Fast Ethernet
Capacity: 0GB
Brand: Synology
