Synology Mesh Router MR2200a - GigE - 802.11a/b/g/n/a rj45 Tri Band
Quicklinx: DYPFWS00 Mfr#: MR2200AC
Type: Wireless router
Connection Type: WAN/LAN
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
Speed: 433Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
18 In Stock
£106.29 ex VAT
£127.54 inc VAT
Synology's first mesh router, MR2200ac, comes with Qualcomm IPQ4019 quad-core CPU and tri-band Wi-Fi, allowing users to expand Wi-Fi coverage through flexible deployment. All Wi-Fi connections and devices can be managed via one platform - SRM. Additionally, settings and remote management can be operated through both a web interface and a dedicated mobile app - DS router.
  • Enhanced connectivity
    With Ethernet 10Base-T/100Base-TX/1000Base-T interfaces and support for both wired and Wi-Fi connections, this router ensures versatile and high-speed connectivity options for all your devices.
  • Robust security
    Featuring advanced encryption algorithms including WEP, WPA-Enterprise, and WPA2-Enterprise, alongside a Stateful Packet Inspection Firewall (SPIF), this router provides a secure networking environment to protect against unauthorized access and threats.
  • Comprehensive network management
    Equipped with features like DHCP server/client, DNS server, NAT support, and static IPv4/IPv6 routing, this router offers full control over your network, ensuring efficient traffic management and reliable Internet connectivity.
  • Multimedia and storage solutions
    With DLNA Media Server, Apple Time Machine compatibility, and USB 3.0 support, this router doubles as a powerful media and storage center, allowing for easy sharing and backup of your digital content.
  • Advanced wireless capabilities
    Thanks to MU-MIMO technology, beamforming technology, and Wi-Fi 5 support, the router delivers a fast and reliable wireless connection that can handle multiple devices simultaneously without compromising on speed or coverage.
Synology MR2200AC - wireless router - Wi-Fi 5 - desktop
Wireless router
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Connection / user qty: 90 , IPv6 routes (static): 100 , IPv4 routes (static): 100
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DDNS
Routing Protocol
Static IPv4 routing, static IPv6 routing
Remote Management Protocol
SNMP, SSH
NAT support, WOL, IGMP snooping, print server, MAC address filtering, IPv6 support, DFS support, VPN passthrough, parental control, Access Point operational mode, firmware upgradable, QoS, RADIUS support, DHCP server, port forwarding, UPnP Media Server, reset button, DNS server, DLNA Media Server, Apple Time Machine compatible, port triggering, SPIF, 3G/4G USB Dongle Support, DHCP client, e-mail notification, VPN Server, SNMP support, MU-MIMO technology, WPS v2, beamforming technology, seamless roaming, DoS protection, DMZ support, cloud station server, traffic monitoring
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v
19.9 cm x 6.5 cm x 15.4 cm
450 g
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Routing Protocol
SNMP, SSH
Encryption Algorithm
WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WEP, WPA3
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, BSMI, JATE, IC, FCC, RoHS, TELEC, KC, VCCI Class B, NCC, iDA, RCM
1 x 717 MHz
RAM
256 MB DDR3 SDRAM
LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
Internal
External power adapter
12.95 watt
1 x network cable
19.9 cm
6.5 cm
15.4 cm
450 g
5 °C
5 - 95%
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11ac
Speed: 433Mbps
Brand: Synology
