Synology HAT5300-12T 12TB 3.5" SATA HDD
Quicklinx: G599WS00 Mfr#: HAT5300-12T
Form Factor: 3.5
Type: Hard drive
Capacity: 12TB
Spin Speed (rpm): 7200rpm
£605.93 ex VAT
£727.11 inc VAT
Marketing description is not available.
  • Scale up confidently
    Synology HAT5300 drives are engineered to provide fast and dependable performance, even for a large number of clients. Firmware and software collaborate to ensure maximum performance, delivering high sequential read performance. HAT5300 provides outstanding performance for large-scale video surveillance, multimedia post-production and enterprise file server environments.
  • Maximum endurance and reliability
    Combined with data protection solutions running on Synology systems, you can confidently depend on your data 24/7 using HAT5300 series drives.
  • Simplified maintenance
    DSM updates will ensure that compatible Synology drives will be updated together with the operating system. This reduces the number of maintenance sessions IT teams need to schedule while also increasing the entire system's service availability. Simplify IT infrastructure planning requirements by getting support for the entire system from Synology.
Synology HAT5300 - hard drive - 12 TB - SATA 6Gb/s
Hard drive - internal
12 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Persistent Write Cache technology
101.85 mm x 147 mm x 26.1 mm
720 g
5-year warranty
Synology SA3400, SA3600; Deep Learning NVR DVA3219, DVA3221; Disk Station DS1520+, DS1618+, DS1621+, DS1621XS+, DS1819+, DS1821+, DS220+, DS2419+, DS3018xs, DS3617xs, DS420+, DS720+, DS920+; RackStation RS1221+, RS1221RP+, RS1619xs+, RS18017XS+, RS2418+, RS2418RP+, RS2818RP+, RS3617RPxs, RS3617xs+, RS3618XS, RS3621RPxs, RS3621xs+, RS4017XS+, RS4021xs+, RS820+, RS820RP+
12 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
720 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
242 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
24x7 Operation
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
4.25 watt (idle) , 7.83 watt (random read/write)
EAC, BSMI, CSA, ICES, KC, RCM, RoHS, TUV, UL
Limited warranty - 5 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 90% (non-condensing)
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Vibration Tolerance (operating)
0.75 g @ 5-300 Hz
Vibration Tolerance (non-operating)
3 g @ 5-500 Hz
Synology SA3400, SA3600 , Synology Deep Learning NVR DVA3219, DVA3221 , Synology Disk Station DS1520+, DS1618+, DS1621+, DS1621XS+, DS1819+, DS1821+, DS220+, DS2419+, DS3018xs, DS3617xs, DS420+, DS720+, DS920+ , Synology RackStation RS1221+, RS1221RP+, RS1619xs+, RS18017XS+, RS2418+, RS2418RP+, RS2818RP+, RS3617RPxs, RS3617xs+, RS3618XS, RS3621RPxs, RS3621xs+, RS4017XS+, RS4021xs+, RS820+, RS820RP+
Form Factor: 3.5
Type: Hard drive
Capacity: 12TB
Brand: Synology
Price Range Ex VAT: £500 - £750
