Scale up confidently
Synology HAT5300 drives are engineered to provide fast and dependable performance, even for a large number of clients. Firmware and software collaborate to ensure maximum performance, delivering high sequential read performance. HAT5300 provides outstanding performance for large-scale video surveillance, multimedia post-production and enterprise file server environments. -
Maximum endurance and reliability
Combined with data protection solutions running on Synology systems, you can confidently depend on your data 24/7 using HAT5300 series drives. -
Simplified maintenance
DSM updates will ensure that compatible Synology drives will be updated together with the operating system. This reduces the number of maintenance sessions IT teams need to schedule while also increasing the entire system's service availability. Simplify IT infrastructure planning requirements by getting support for the entire system from Synology.
- Synology HAT5300 - hard drive - 12 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 12 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Persistent Write Cache technology
- 101.85 mm x 147 mm x 26.1 mm
- 720 g
- 5-year warranty
- Designed For
- Synology SA3400, SA3600; Deep Learning NVR DVA3219, DVA3221; Disk Station DS1520+, DS1618+, DS1621+, DS1621XS+, DS1819+, DS1821+, DS220+, DS2419+, DS3018xs, DS3617xs, DS420+, DS720+, DS920+; RackStation RS1221+, RS1221RP+, RS1619xs+, RS18017XS+, RS2418+, RS2418RP+, RS2818RP+, RS3617RPxs, RS3617xs+, RS3618XS, RS3621RPxs, RS3621xs+, RS4017XS+, RS4021xs+, RS820+, RS820RP+
- Capacity
- 12 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- Bytes per Sector
- 512
- 101.85 mm
- 147 mm
- 26.1 mm
- 720 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 242 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,500,000 hours
- 24x7 Operation
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 4.25 Watt (idle) , 7.83 Watt (random read/write)
- CSA, UL, TUV, BSMI, RoHS, ICES, KC, EAC, RCM
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- 5 - 90% (non-condensing)
- Shock Tolerance (operating)
- 70 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 2 ms
- Vibration Tolerance (operating)
- 0.75 g @ 5-300 Hz
- Vibration Tolerance (non-operating)
- 3 g @ 5-500 Hz
- Designed For
- Synology SA3400, SA3600 , Synology Deep Learning NVR DVA3219, DVA3221 , Synology Disk Station DS1520+, DS1618+, DS1621+, DS1621XS+, DS1819+, DS1821+, DS220+, DS2419+, DS3018xs, DS3617xs, DS420+, DS720+, DS920+ , Synology RackStation RS1221+, RS1221RP+, RS1619xs+, RS18017XS+, RS2418+, RS2418RP+, RS2818RP+, RS3617RPxs, RS3617xs+, RS3618XS, RS3621RPxs, RS3621xs+, RS4017XS+, RS4021xs+, RS820+, RS820RP+
