Synology FS3600 24 Bay Rack Mountable NAS
Quicklinx: FW69WS00 Mfr#: FS3600
Type: NAS server
Controller Type: RAID
  • Xeon
£9,694.48 ex VAT
£11,633.37 inc VAT
FS3600 is a 24-bay all-flash Synology NAS for enterprise use that boosts the performance of I/O sensitive applications, such as databases, virtual machines, or online transaction processing (OLTP).
  • Fully certified storage virtualization solutions
    Synology iSCSI storage fully supports most virtualization solutions to enhance work efficiency with easy management interface. VMware vSphere 6 and VAAI integration helps offload storage operations and optimizes computation efficiency. Windows Offloaded Data Transfer (ODX) speeds up data transfer and migration rate. OpenStack Cinder support turns your Synology NAS into a block-based storage component.
  • Real-time collaboration on your private cloud
    Synology Office is a collaboration package combining the convenience and usability of the public cloud with private cloud privacy and security. It enables seamless collaboration on documents and spreadsheets in a protected environment.
  • Next-generation file system for better data protection
    The Btrfs file system introduces advanced storage technologies and optimized snapshots to prevent data corruption and reduce maintenance overheads. It offers flexible, efficient data protection and recovery tools while ensuring high-level data integrity.
Synology FlashStation FS3600 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
0 (installed) / 24 (max)
48.2 cm x 72.4 cm x 8.8 cm
14.9 kg ()
1 x Intel Xeon D-1567 2.1 GHz (12-core)
Storage Controller
RAID RAID 0, 1, 5, 6, 10, JBOD, RAID F1
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
IP Cameras Supported
128
RAM
16 GB
5-year warranty
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
48.2 cm
72.4 cm
8.8 cm
14.9 kg ()
Processor / Memory
Processors Installed
Number of Cores
12-core
Max Supported Qty
1
Max Turbo Speed
2.7 GHz
RAM
16 GB (installed) / 128 GB (supported) - DDR4
Registered, ECC
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1
Network / Transport Protocol
PPTP, L2TP, iSCSI, SMTP, FTP, SMB, NFS, HTTPs
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH, SMTP, LDAP
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, VPN support, LDAP support, WOL, antivirus analysis, High Availability, anti-malware protection, ACL support, e-mail server, reset button, bandwidth control, surveillance station, VPN Server, Link Aggregation, failover protection, OpenStack compatible, Btrfs, file station, EXT4 file system, iSCSI LUN clone/snapshot, Windows ODX, MailPlus server
Encryption Algorithm
AES-NI
Security DVR
128
Compression Format
MJPEG, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
24 (total) / 24 (free) x hot-swap - 2.5"
Expansion Slots
1 x PCI Express 3.0 x8 , 4 (total) / 3 (free) x DIMM 288-pin
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x serial - DB-9 , 2 x Ethernet 10Gb - RJ-45
Built-in 4 cooling fans
VCCI, BSMI, FCC, RoHS, EAC, RCM
Accessory pack
Internal power supply
Installed Qty
2
Max Supported Qty
2
258.23 Watt
Power Provided
500 Watt
Limited warranty - 5 years
35 °C
5 - 95%
Sound Emission
57 dBA
Type: NAS server
Brand: Synology
Price Range Ex VAT: £1500+
