Featuring powerful hardware, FS3400 provides an astounding random/write IOPS, meeting the needs for real-time analytics, online transaction processing, and mission-critical database services.
Active backup for business
Centralize backup tasks for VMware and file servers. Restore whatever you want fast and reliably when needed. -
Hyper backup
Comprehensively back up your data to a local shared folder, an external device, another Synology NAS, an rsync server, or a public cloud to ensure data safety. -
Virtual machine manager
Run various operating systems in isolated sandboxes. Seamlessly clone, restore and migrate virtual machines.
- Synology FlashStation FS3400 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Installed Devices / Modules Qty
- 0 (installed) / 24 (max)
- 48.2 cm x 72.4 cm x 8.8 cm
- 14.9 kg ()
- Processor
- 1 x Intel Xeon D-1541 2.1 GHz (8-core)
- Storage Controller
- RAID RAID RAID 0, 1, 5, 6, 10, JBOD, RAID F1
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE, 10GbE
- IP Cameras Supported
- 100
- RAM
- 16 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 7 or later, Apple MacOS X 10.11 or later
- 5-year warranty
- NAS server
- Host Connectivity
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 48.2 cm
- 72.4 cm
- 8.8 cm
- 14.9 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- 8-core
- Max Supported Qty
- 1
- Max Turbo Speed
- 2.7 GHz
- RAM
- 16 GB (installed) / 128 GB (supported) - DDR4
- Registered, ECC
Storage Controller
- RAID
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1
- Data Link Protocol
- PPTP, L2TP, iSCSI, SMTP, FTP, SMB, NFS, HTTPs
- Remote Management Protocol
- SNMP, Telnet, HTTPS, SSH, SMTP, LDAP
- Network Services Compatibility
- Microsoft Active Directory (AD), Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, VPN support, LDAP support, wake on LAN (WOL), antivirus analysis, High Availability, anti-malware protection, Access Control List (ACL) support, e-mail server, reset button, bandwidth control, surveillance station, VPN Server, Link Aggregation, failover protection, OpenStack compatible, B-tree file system (Btrfs), file station, EXT4 file system, iSCSI LUN clone/snapshot, Windows ODX, MailPlus server
- Encryption Algorithm
- AES-NI
Security DVR
- 100
- Compression Format
- MJPEG, H.264, H.265
- Image Resolution
- 1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
- Expansion Bays
- 24 (total) / 24 (free) x hot-swap - 2.5"
- Expansion Slots
- 1 x PCI Express 3.0 x8 , 4 (total) / 3 (free) x DIMM 288-pin
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x serial - DB-9 , 2 x Ethernet 10Gb - RJ-45
- Built-in 4 cooling fans
- VCCI, BSMI, FCC, RoHS, EAC, RCM
- Included Accessories
- Accessory pack
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Voltage Required
- 313.84 Watt
- Power Provided
- 500 Watt
- OS Required
- Limited warranty - 5 years
- 0 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 57 dBA
