Synology FlashStation FS6400 24 Bay Rack-Mountable
Quicklinx: FB2CWS00 Mfr#: FS6400
Type: NAS server
Controller Type: RAID
£13,212.01 ex VAT
£15,854.41 inc VAT
Uncompromising performance - Synology FlashStation FS6400 is a 2U rackmount server designed for I/O-intensive and latency-sensitive tasks, ideal for multimedia post-production, virtual machines, online transaction processing, or database applications.
CPU: Dual Intel Xeon Silver 8-core with NUMA, Memory: DDR4 ECC RDIMM, up to 512GB, High Performance: Over 240,000 iSCSI 4K random write IOPS, Scalability: Up to 72 drives with RX2417sas1
With multi-LAN design, FS6400 is capable of performing Link Aggregation and failover. For environments requiring a higher speed, two optional Ethernet add-in cards can be installed on PCIe 3.0 slots to provide fast data transmission.
  • Fast and reliable networking
  • Complete iSCSI and virtualization solutions
    Synology iSCSI storage supports most virtualization solutions such as VMware vSphere, Microsoft Hyper-V, Citrix Xen Server, and OpenStack Cinder to enhance work efficiency.
  • Next-generation file system for better data protection
    The Btrfs file system introduces advanced storage technologies and optimized snapshots to prevent data corruption and reduce maintenance overheads. It offers flexible, efficient data protection and recovery tools while ensuring high-level data integrity.
  • RAID F1
    Due to the peculiarities of SSD and RAID technology, a common challenge lies in how to prevent all of the drives from failing at the same time because of the evenly distributed workload. RAID F1 alleviates this problem with a specially designed algorithm to unevenly distribute workload to drives, enhancing the resilience of the storage pool and ensuring your data remains safe.
Synology FlashStation FS6400 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
0 (installed) / 24 (max)
48.2 cm x 72.4 cm x 8.8 cm
17.26 kg ()
2 x Intel Xeon Silver 4110 2.1 GHz (8-core)
Storage Controller
RAID RAID 0, 1, 5, 6, 10, JBOD, RAID F1
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
IP Cameras Supported
128
RAM
32 GB
Power Redundancy
Microsoft Windows 7 or later, Apple MacOS X 10.11 or later
5-year warranty
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
48.2 cm
72.4 cm
8.8 cm
17.26 kg ()
Processor / Memory
Processors Installed
Number of Cores
8-core
Max Turbo Speed
3 GHz
RAM
32 GB (installed) / 512 GB (supported) - DDR4
Registered, ECC
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1
Network / Transport Protocol
PPTP, L2TP, iSCSI, SMTP, FTP, SMB, HTTPs
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH, SMTP, LDAP
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, VPN support, LDAP support, WOL, antivirus analysis, High Availability, anti-malware protection, ACL support, e-mail server, reset button, bandwidth control, surveillance station, VPN Server, failover protection, OpenStack compatible, Btrfs, file station, EXT4 file system, iSCSI LUN clone/snapshot, Windows ODX, MailPlus server
Encryption Algorithm
AES-NI
Security DVR
128
Compression Format
MJPEG, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
24 (total) / 24 (free) x hot-swap - 2.5"
Expansion Slots
2 x PCI Express 3.0 x8 , 16 (total) / 14 (free) x DIMM 288-pin
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x serial - DB-9 , 2 x Ethernet 10Gb - RJ-45
Built-in 4 cooling fans
VCCI, BSMI, FCC, RoHS, EAC, RCM
Accessory pack
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
288.49 Watt
Power Provided
800 Watt
Limited warranty - 5 years
35 °C
5 - 95%
Sound Emission
53.7 dBA
Type: NAS server
Brand: Synology
Price Range Ex VAT: £1500+
