Synology DX513 40TB (5 x 8TB WD Red) 5 Bay Desktop Expansion Unit
Quicklinx: C2BDWS00 Mfr#: DX513/40TB-RED
Synology DX513 delivers an effortless solution for volume expansion and data backup for selected Synology DiskStation models. The DX513 seamlessly scales up the storage capacity of the DiskStation by additional 5 hard drives on-the-fly when connected directly to an expansion cable.
  • Volume expansion and backup
    When running out of hard drive capacity on the Synology DiskStation, Synology DX513 provides an easy way to immediately scale capacity by additional 5 hard drives. The RAID volume on the Synology DiskStation can be expanded directly without having to reformat the existing hard drives, ensuring the Synology DiskStation continues its service during the capacity expansion. Synology DX513 can be used as a dedicated local backup solution for the Synology DiskStation. When created as a separate volume, the Synology DX513 provides a great backup solution to its local hard disks in case of system failure.
  • Reliable plug-and-use design
    The Synology DX513 is connected to the Synology DiskStation using an expansion cable with custom-designed connectors on both ends, ensuring a reliable connection and maximum throughput. The 3.0 Gbps connection speed allows the hard drives in the connected Synology DX513 to operate as the internal ones of Synology DiskStation.
  • Green and easy to manage
    The HDD hibernation and system hibernation can be manually configured to take effect automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of the hard disk. The DX513 will also smartly power on/off with the attached DiskStation, so no user intervention is needed to keep this system running smartly and efficiently.
Synology DX513 - storage enclosure
Storage enclosure
5 (installed) / 5 (max)
Supported Drives
SATA-600
Hard Drive
5 x 8 TB HDD - hot-swap
AC 120/230 V - 50/60 Hz
24.8 cm x 23.3 cm x 15.7 cm
3.91 kg
3-year warranty
Storage enclosure
Chassis
5
Supported Devices / Modules Qty
5
Supported Drives
SATA-600
Hard Drive
HDD - hot-swap
5 x 8 TB
Expansion Bays
5 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
1 x eSATA
Built-in 2 cooling fans
1 x eSATA cable
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
Internal power supply
45.1 Watt
24.8 cm
23.3 cm
15.7 cm
3.91 kg
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
21.5 dBA
