Synology DX1215 delivers an effortless volume expansion and data backup solution for selected Synology DiskStation servers by providing an additional 12 drive slots with SATA III 6Gb/s interface support.
Volume expansion & backup
When drive capacity is running low on a Synology DiskStation, Synology DX1215 provides an easy way to immediately scale capacity by providing an additional 12 drive slots. A RAID volume on the Synology DiskStation can be expanded directly without having to reformat the existing drives, ensuring the Synology DiskStation continues providing services during capacity expansion. Synology DX1215 can serve as a dedicated local backup solution for a Synology DiskStation. When created as a separate volume, the Synology DX1215 provides a great backup solution for local drives in case of system failure. -
Reliable Plug-and-Use design
DX1215 securely connects to Synology's DiskStation servers with a specially designed expansion cable, ensuring easy connection and maximum data throughput. The 6Gb/s connection speed allows the drives in the connected Synology DX1215 to operate as the internal ones of Synology DiskStation. -
Green & easy to manage
Hibernation mode can be manually configured to start automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of hard drives. DX1215 will also smartly power on/off with the attached DiskStation, so no user intervention is needed to keep this system running smartly and efficiently.
- Synology DX1215 - hard drive array - TAA Compliant
- Hard drive array
- Total Array Capacity
- 120 TB
- Interface
- InfiniBand
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- Supported Drives
- SATA-600
- Storage Controller
- (SATA 6Gb/s)
- Hard Drive
- 12 x 10 TB HDD SATA 6Gb/s - hot-swap
- Power
- AC 120/230 V - 50/60 Hz
- TAA Compliant
- 27 cm x 30 cm x 34 cm
- 9.02 kg
- 5-year warranty
- Hard drive array
Chassis
- 12
- Supported Devices / Modules Qty
- 12
- Supported Drives
- SATA-600
Storage
- 120 TB
- HDD Array External Interface
- InfiniBand
Storage Controller
- Interface Type
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
Hard Drive
- HDD - hot-swap
- Capacity
- 12 x 10 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 3.5"
- 1 x InfiniBand
- Cables Included
- 1 x InfiniBand cable
- FCC Class B certified, RoHS, BSMI Class B
- TAA Compliant
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 500 Watt
- 27 cm
- 30 cm
- 34 cm
- 9.02 kg
- Limited warranty - 5 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 27.2 dBA
