Synology DS918+ 4 Bay Diskless NAS
Quicklinx: D47LWS00 Mfr#: DS918+
Interface: Fast Ethernet, Ethernet, Gigabit Ethernet
Capacity: 0GB
Type: 4-Bay
  • Celeron
£453.15 ex VAT
£543.78 inc VAT
High-speed scalable storage server
Synology DS918+ is designed for small and medium-sized businesses and IT enthusiasts. With a powerful built-in AES-NI hardware encryption engine, DS918+ provides exceptional encrypted file transmission. Also capable of transcoding up to two channels of H.265/H.264 4K videos at the same time, DS918+ is ideal for sharing and storing ultra-high definition media content.
  • Satisfy your need for performance and capacity
    DS918+ supports up to two M.2 NVMe 2280 SSDs, allowing fast system cache creation without occupying internal drive bays. Scalable up to 9 drives with a Synology Expansion Unit DX517, DS918+ answers the need for flexible storage capacity.
  • Btrfs - next-generation storage efficiency
    Btrfs file system features the advanced storage technologies to meet the management needs of modern large scale businesses:
  • Digital asset protection
    Powered by Synology DiskStation Manager (DSM), Synology NAS offers advanced security measures to protect against sudden data loss and potential security holes.
  • Synchronize files across your devices
    Cloud Station Suite provides real-time data synchronization across all your devices, such as computers, mobile devices, and other Synology NAS whenever a file is modified. "Intelliversioning" keeps the most important file versions to better utilize storage space.
  • 4K multimedia server
    Access and stream your 4K media content anytime and anywhere. DS918+ supports 4K H.264/H.265 online transcoding via Video Station and DS video, allowing 4K videos to be converted and played on the fly on other computers, smartphones, and media players that originally do not support Ultra HD formats.
  • Security advisor
    Analyzes system settings, password strength, network preferences, and removes any possible malware.
  • AES 256-bit encryption
    Encrypt shared folders and network data transmission to keep data from unauthorized access.
  • 2-step verification
    Prevent others from logging in to your DSM by generating a one-time password (OTP) on your mobile device.
Synology Disk Station DS918+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
40 TB
0 (installed) / 4 (max)
19.9 cm x 22.3 cm x 16.6 cm
2.28 kg ()
1 x Intel Celeron J3455 1.5 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s / eSATA RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
RAM
4 GB
Storage Operating System
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
40 TB
19.9 cm
22.3 cm
16.6 cm
2.28 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.3 GHz
RAM
4 GB (installed) / 8 GB (supported) - DDR3L
Storage Controller
RAID
Interface Type
SATA 6Gb/s / eSATA
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
PPTP, L2TP, iSCSI, SMB
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, ACL support, FTP server, VPN Server
Encryption Algorithm
SSL, TLS, AES-NI
DLNA CERTIFIED
Security DVR
Compression Format
MPEG-2, H.264, H.265, VC-1
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 4096x2160
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 x M.2
2 x USB 3.0 , 2 x Ethernet 1000Base-T - RJ-45 , 1 x eSATA
2 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, hardware encryption
Security Slot Type
Kensington security slot
FCC Class B certified, RoHS, BSMI Class B
External power adapter
28.8 Watt
Power Consumption Stand by
12.6 Watt
Power Provided
100 Watt
Limited warranty - 3 years
5 °C
5 - 95%
Sound Emission
19.8 dBA
Capacity: 0GB
Interface: Ethernet
Interface: Gigabit Ethernet
Type: 4-Bay
Brand: Synology
