Synology DS720+ 2 Bay NAS
Quicklinx: FW6BWS00 Mfr#: DS720+
  • Celeron
Synology DiskStation DS720+ is a compact network-attached storage solution designed to streamline data and multimedia management. Two built-in M.2 SSD slots and Synology SSD Cache technology allow you to boost system I/O and application performance. With scalable storage design, DS720+ lets you start small and expand storage capacity as your data grows.
  • Streamline your data management experience
    Synology DS720+ is a powerful 2-bay desktop NAS that brings you a fast and smooth data management experience, as well as 225 MB/s sequential read and 195 MB/s sequential write throughput. It benefits computing-intensive applications, speeding up Synology Drive and Moments, and boosting Web PHP response efficiency, making data management simple and efficient. DS720+ is equipped with two built-in M.2 SSD slots that support Synology SSD Cache technology, allowing you to reduce random I/O response time significantly without occupying front drive bays.
  • Establish a strong storage foundation with Btrfs
    DS720+ features a Btrfs file system optimized by Synology to offer you high reliability and high performance. Btrfs supports advanced storage technologies that meet the needs of modern business. Advanced snapshot technology provides schedulable and near-instantaneous data protection of shared folders and LUNs. File and folder level data restoration offers users who wish to restore only a specific file or folder more flexibility. Flexible Shared Folders and User Quota System provide comprehensive quota control on all user accounts and shared folders. File self-healing allows Btrfs file systems to auto-detect corrupted files using mirrored metadata and to recover broken data using RAID configurations. Inline compression compresses data before writing them to the drive, to optimize storage use and reduce write commands to the drives.
  • Powerful backup tools
    DS720+ offers users a range of backup solutions for cloud and physical, on-premises environments. Backing up and restoring data is effortless - and completely free of licenses on compatible NAS models. Back up your cloud data: Cloud Sync enables users to seamlessly back up or synchronize data between a local Synology NAS and other cloud services. Back up your PCs and servers: Synology Drive Client backs up your Windows, Mac, and Linux desktop devices to safeguard important computer files. Back up your Synology NAS: Hyper Backup offers a wide range of destinations for backups of your NAS, including on-premises and cloud.
  • Automated video surveillance system
    With Synology Surveillance Station, DS720+ can act as a full-featured video surveillance system. Simply add network-connected cameras and you can monitor their live feeds, play back recordings, and receive instant event alerts right away. Access your surveillance system from a web browser, the desktop client, or the DS cam mobile app anytime, anywhere. Set up rules to trigger specific actions when predefined events occur, such as automatically taking snapshots when motion is detected. Get notified by email, SMS, or push notification so that you can intervene in time.
Synology Disk Station DS720+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
32 TB
0 (installed) / 2 (max)
10.6 cm x 22.3 cm x 16.6 cm
1.51 kg ()
1 x Intel Celeron J4125 2 GHz (Quad-Core)
Storage Controller
RAID RAID 0, 1, JBOD
10Mb LAN, 100Mb LAN, 1GbE
RAM
2 GB
Apple MacOS, Linux, Microsoft Windows, Android, Apple iOS
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
32 TB
10.6 cm
22.3 cm
16.6 cm
1.51 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.7 GHz
RAM
2 GB (installed) / 6 GB (supported) - DDR4
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, JBOD
Network / Transport Protocol
PPTP, L2TP, IPSec, SMTP, FTP, POP3, IMAP, SMB, NFS, HTTP, HTTPs
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH, LDAP
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
WOL, High Availability, download client, ACL support, RADIUS support, iTunes server, e-mail server, reset button, surveillance station, DNS server, DLNA Media Server, WebDAV server, VPN Server, Dropbox support, Link Aggregation, failover protection, AES encryption, Yandex Disk support, Microsoft OneDrive support, DLNA support, hubiC support, SSD trim, Amazon S3 support, Backblaze B2 support, MegaDisk support
Encryption Algorithm
AES-NI
Expansion Bays
2 (total) / 2 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 2 (free) x M.2 2280
2 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45 , 1 x eSATA
2 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan
Security Slot Type
Kensington security slot
VCCI, BSMI, CCC, FCC, RoHS, KC, EAC, RCM
Accessory pack
External power adapter
16.44 Watt
Power Consumption Stand by
6.19 Watt
Power Provided
65 Watt
Software Included
McAfee
Limited warranty - 3 years
5 - 95%
Sound Emission
18.4 dBA
Hard Drives
FW6B Synology HAT5300-12T 12TB 3.5" SATA HDD In Stock £422.60
