Powered by an Intel Celeron J3455 quad-core processor and AES-NI hardware encryption engine, DS718+ delivers excellent file transfer speeds. With the scalability to expand up to 7 drives with Synology Expansion Unit DX517 and the support for real-time 4K/1080p video transcoding, DS718+ is ideal for centralizing data backup and storing ultra-high definition media contents.
Desktop backup
Simplified backup solution for your Mac, PC, and mobile devices. -
Hyper backup
Store multiple backup versions with block-level incremental data backup and cross-version deduplication. -
Comprehensive security
Comprehensive built-in security tools are constantly updated to tackle evolving threats and protect your devices. -
All-in-one server
Save additional investment by integrating various network services, web/mail services, management applications into your NAS.
- Synology Disk Station DS718+ - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Max Supported Capacity
- 28 TB
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- 10.35 cm x 23.2 cm x 15.7 cm
- 1.74 kg ()
- Processor
- 1 x Intel Celeron J3455 1.5 GHz (Quad-Core)
- Storage Controller
- RAID RAID 0, 1, 5, 6, 10, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 40
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 28 TB
- 10.35 cm
- 23.2 cm
- 15.7 cm
- 1.74 kg ()
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- Max Turbo Speed
- 2.3 GHz
- RAM
- 2 GB (installed) / 6 GB (supported) - DDR3L
Storage Controller
- RAID
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
- Data Link Protocol
- TCP/IP, PPTP, L2TP, IPSec, iSCSI, FTP, SMB, NFS, SFTP
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), File Level Security (ACLs), Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV), SFTP
- Firewall protection, hardware encryption, VPN support, LDAP support, WOL, manageable, web server, backup server, download client, file sharing, anti-malware protection, event log, ACL support, SSH support, iTunes server, FTP server, SMS alert, BitTorrent Client, e-mail server, reset button, bandwidth control, surveillance station, PXE support, DLNA Media Server, Apple Time Machine compatible, eMule client, e-mail notification, 4K resolution support, cloud backup, VPN Server, Dropbox support, anti-virus protection, mobile users support, Link Aggregation, Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support
- Encryption Algorithm
- SSL, TLS, AES-NI
Security DVR
- 40
- Compression Format
- H.264
- Expansion Bays
- 2 (total) / 2 (free) - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x eSATA
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), wake on LAN, lockable, built-in cooling fan, hardware encryption, scheduled power on/off
- Security Slot Type
- Kensington security slot
- RoHS, TLS
- Power Device
- External power adapter
- Voltage Required
- OS Required
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 5 - 95%
