Synology DS715/4TB-RED 2 Bay NAS
Quicklinx: BK9VWS00 Mfr#: DS715/4TB-RED
DS715 is an expandable NAS server, equipped with a powerful processor and hardware encryption engine which delivers speedy performance for small business workgroups with growing needs. With dual LAN ports featuring failover and Link Aggregation, plus High Availability, DS715 offers a reliable storage solution to protect your precious data.
  • Hardware encryption engine
    Encrypting data is essential to a healthy security policy. Equipped with a dedicated hardware encryption engine, DS715 is the ideal digital locker for sensitive data; files and folders are encrypted on the fly without any perceived performance loss. DS715 delivers encrypted data transmission speeds over 205.58 MB/s reading and 77.62 MB/s writing.
  • Dual LAN with failover and Link Aggregation support
    Equipped with two Gigabit LAN ports featuring failover and Link Aggregation support, DS715 ensures continual network service in case one LAN connection fails, and enhances connection speeds beyond the limits of a single cable or port.
  • Robust NVR server for monitoring your environment
    DS715 is an robust NVR server, it is capable of hosting up to 30 IP cameras (900 FPS @ 720p). Powered by Surveillance Station, DS715 allows SMBs to centralize IP camera management and integration for door monitoring, as well as safeguard the environment by watching live view, recording events, and taking snapshots with a computer or mobile device.
  • All-in-one server
    With just one DS715, it's possible to handle a vast amount of tasks. DS715 helps your company gain a competitive edge by acting as your multi-function server. Directory Server provides LDAP service, while DNS and DHCP packages allow you to host a domain name server and automate network IP assignment at no extra cost. With Synology's Proxy Server, you can regulate content access and monitor who can access which website while saving bandwidth. You can host up to 30 websites with Web Station, safeguard the office environments with Surveillance Station, send and receive mails using your own email domain with Mail Station, share printing capability with Printer Server, make DS715 act as a VPN server to access company's resources remotely, and more.
  • Ensuring business continuity
    Uninterrupted availability is a critical goal for all businesses. DS715 supports Synology High Availability (SHA) technology which combines an active and passive server into one cluster, the former always mirrored to the latter. The Heartbeat mechanism detects regular "heartbeats" between the two servers. If the main server encounters unexpected downtime, the passive server immediately takes over. With multiple LAN ports, DS715 also ensures redundancy in the event of unexpected network failure.
Synology Disk Station DS715 - NAS server - 4 TB - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
4 TB
2 (installed) / 2 (max)
10.35 cm x 23.2 cm x 15.7 cm
1.69 kg ()
1 x 1.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s / eSATA RAID RAID 0, 1, JBOD
Hard Drive
2 x 2 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
25
RAM
2 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
4 TB
10.35 cm
23.2 cm
15.7 cm
1.69 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
1 x 1.4 GHz
Number of Cores
Quad-Core
RAM
2 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s / eSATA
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 2 TB
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, LPR/LPD, SMTP, FTP, DHCP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, IPP, HTTPS, SSH
Network Services Compatibility
DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), Syslog support, print server, antivirus analysis, High Availability, IP address filtering, web server, backup server, download client, file sharing, Access Control List (ACL) support, RADIUS support, iTunes server, DHCP server, FTP server, e-mail server, UPnP Media Server, reset button, bandwidth control, surveillance station, DNS server, DLNA Media Server, Apple Time Machine compatible, eMule client, e-mail notification, cloud backup, VPN Server
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
25
Expansion Bays
2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
2 x USB 3.0 - Type A , 1 x eSATA , 2 x Ethernet 1000Base-T - RJ-45
2 x network cable
Wake on LAN, lockable, built-in cooling fan, AirPrint, Google Cloud Print
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
External power adapter
21.37 Watt
Power Provided
72 Watt
Software Included
Drivers & Utilities
TAA Compliant
5 °C
35 °C
5 - 95%
