Synology DS418Play 4 Bay Diskless NAS
Quicklinx: D47KWS00 Mfr#: DS418play
  • Celeron
Synology DS418play is designed to be your ideal, centralized multimedia hub with over 40 TB of raw storage capacity, allowing you to transcode up to 2 channels of H.265/H.264 4K videos at the same time. With a powerful built-in AES-NI hardware encryption engine, DS418play also provides excellent encrypted file transmission.
  • 4K multimedia server
    Access and stream your 4K media content anytime and anywhere. DS418play supports 4K H.264/H.265 online transcoding via Video Station and DS video, allowing 4K videos to be converted and played on the fly on other computers, smartphones, and media players that originally do not support Ultra HD formats.
  • Next-generation file system for better data protection
    The Btrfs file system introduces advanced storage technologies and optimized snapshots to prevent data corruption and reduce maintenance overhead. While ensuring high-level data integrity, it also offers flexible, efficient data protection and recovery tools.
  • Synology Hybrid RAID (SHR) technology
    Storage management is easy with Synology Hybrid RAID (SHR) technology. SHR is an automated RAID management system allowing you to easily create and expand storage volumes and migrate RAID types without requiring details on RAID. SHR provides 1 to 2-disk redundancy to safeguard your data during drive failures.
Synology Disk Station DS418Play - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
40 TB
0 (installed) / 4 (max)
19.9 cm x 22.3 cm x 16.6 cm
2.23 kg ()
1 x Intel Celeron J3355 2 GHz (Dual-Core)
Storage Controller
RAID RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
Performance
Throughput (reading): 226 MB/s , Throughput (writing): 185 MB/s
RAM
2 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
40 TB
19.9 cm
22.3 cm
16.6 cm
2.23 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
Max Turbo Speed
2.5 GHz
RAM
2 GB (installed) / 6 GB (supported) - DDR3L
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
PPTP, L2TP, IPSec, SMTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Performance
Firewall protection, hardware encryption, LDAP support, WOL, download client, ACL support, SSH support, iTunes server, Samba support, FTP server, reset button, bandwidth control, surveillance station, Energy Efficient Ethernet, WebDAV server, 4K resolution support, cloud backup, VPN Server, security lock slot (cable lock sold separately), 2 fans, Dropbox support, automated backup scheduling, Wi-Fi USB dongle support, Link Aggregation, Google Drive support, failover protection, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support, OpenStack compatible, Full HD (1920 x 1080) streaming video support, file station, hubiC support, OpenStack Swift-compatible, WebDAV server support, Baidu cloud support
Encryption Algorithm
SSL, TLS, AES-NI
DLNA CERTIFIED, UPnP
Security DVR
Compression Format
MPEG-2, H.264, H.265, VC-1
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160, 4096x2160
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 1 (free) x SO-DIMM 204-pin
2 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
2 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, hardware encryption, scheduled power on/off
Security Slot Type
Kensington security slot
FCC Class B certified, RoHS, BSMI Class B
External power adapter
29.01 Watt
Power Provided
90 Watt
5 °C
5 - 95%
