DS418j is a 4-bay NAS server designed for home and personal users to effectively manage, protect and share data. Its 64-bit dual-core processor supports over 40 TB raw single volume capacity for flexible data management.
Centralized backup storage for your computers
Back up any devices, whether it is a Windows computer, Mac, or other devices. Synology's comprehensive multi-version backup solution can protect your PC and NAS against malicious attacks including the rising encryption-based ransomware threats. -
Synology Hybrid RAID (SHR) technology
Storage management is easy with Synology Hybrid RAID (SHR) technology. SHR is an automated RAID management system allowing you to easily create and expand storage volumes and migrate RAID types without requiring details on RAID. SHR provides 1 to 2-disk redundancy to safeguard your data during drive failures. -
Easy file access with QuickConnect
Access files on your Synology NAS over the Internet without the hassle of setting up port forwarding rules, DDNS, or other complicated network settings. QuickConnect allows you to connect via a simple customizable address, so that you can instantly access media and work files on any Windows/Mac/Linux computer, laptop, or mobile device without additional charge.
- Synology Disk Station DS418j - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Max Supported Capacity
- 40 TB
- Installed Devices / Modules Qty
- 0 (installed) / 4 (max)
- 16.8 cm x 23 cm x 18.4 cm
- 2.21 kg ()
- Processor
- 1 x Realtek Semiconductor RTD1293 1.4 GHz (Dual-Core)
- Storage Controller
- RAID RAID RAID 0, 1, 5, 6, 10, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 16
- RAM
- 1 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 40 TB
- 16.8 cm
- 23 cm
- 18.4 cm
- 2.21 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 1 GB DDR4
Storage Controller
- RAID
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
- Data Link Protocol
- PPTP, L2TP, SMTP, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- LDAP support, wake on LAN (WOL), Syslog support, Access Control List (ACL) support, SSH support, surveillance station, VPN Server
- DLNA CERTIFIED
Security DVR
- 16
- Compression Format
- MJPEG, H.264
- Image Resolution
- 1280x720, 1920x1080, 2048x1536, 2591x1944
- Expansion Bays
- 4 (total) / 4 (free) x internal - 2.5" / 3.5"
- 2 x USB 3.0 , 1 x Ethernet 1000Base-T - RJ-45
- Cables Included
- 1 x network cable
- Security Slot Type
- Kensington security slot
- FCC Class B certified, RoHS, BSMI Class B
- Power Device
- External power adapter
- Voltage Required
- 21.22 Watt
- Power Provided
- 90 Watt
- OS Required
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 5 - 95%
- Sound Emission
- 20.6 dBA
