Synology DS415Play 24TB-Red 4 Bay NAS
Quicklinx: B0HGWS00 Mfr#: DS415PLAY/24TB-RED
  • Atom
Synology DiskStation DS415play is designed to centralize your multimedia collections and share them effortlessly in your home network. Optimized for multimedia processing, DS415play delivers on-demand Full HD transcoding to guarantee seamless streaming experiences to the widest range of gadgets in your home.
  • Built to entertain
    Synology DS415play is a ready media server specifically designed for users who have a huge multimedia library and are eager to share them. With up to four drive bays, DS415play allows for flexible RAID configurations to achieve efficient data redundancy. DS415play comes with dual core CPU and 1 GB RAM, delivering an average 112.45 MB/sec reading and 101.21 MB/sec writing speed under RAID 5 configuration in a Windows environment. 1 Powered by hardware accelerated transcoding engine, DS415play features 1080p Full HD video transcoding on the fly, effortlessly sharing videos with your smart TV, network media player, mobile devices and PC. DS415play comes with the external interfaces you need - up to three USB 2.0 ports to power multiple peripheral devices concurrently, and another two USB 3.0 ports for high speed external storage exchange. Designed with both safety and convenience in mind, DS415play contains hot-swappable tool-less hard drive trays to enable hassle-free hard drive installation and risk-free hard drive replacement.
  • Full multimedia features
    With DS415play you can easily manage your multimedia contents and share them with smart TV, Android TV box, network media player, tablets and phones, Windows PC, Mac, and Linux computers. Photo Station's intuitive design allows you to effortlessly organize photos into customized categories, smart albums and blog posts, and link them to social networking websites like Facebook, Twitter, Plurk, Picasa, Weibo and QQ within a few clicks. Audio Station comes with a built-in lyrics plugin, Internet radio, and support for DLNA, AirPlay, and Bluetooth speakers for quality playback. With Video Station, movies and seasons of TV shows are automatically indexed with online metadata. You can also record your favorite programs with DTV tuners.
  • DLNA-certified media server
    A certified DLNA DMS (Digital Media Server), DS415play serves also as a ready media server with the capability to host digital multimedia contents for remote playback. DLNA-compliant devices can access the shared contents in DS415play in the same local area network without the fuss over privilege settings. Not only does it make your multimedia bank available without any preconfiguration, Synology mobile apps transform your mobile device into the remote control of your DS415play, sending movies and photos to your TV or music to your speaker right from the palm of your hand.
  • Energy efficient with cool and quiet design
    Synology DS415play is designed with energy efficiency in mind. Not only does it provide two 92 x 92 mm fans and smart airflow to keep the system running cool 24/7, its noise dampening design makes it really quiet compared to PC counterparts. The hard drive hibernation can further reduce power consumption and operation cost. All Synology products are produced with RoHS compliant parts and packed with recyclable packing materials. Synology acknowledges the responsibility as a global citizen to continually work to reduce the environmental impact of every product produced.
Synology Disk Station DS415play - NAS server - 24 TB - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
24 TB
Max Supported Capacity
24 TB
4 (installed) / 4 (max)
20.3 cm x 23.32 cm x 16.5 cm
2.03 kg ()
1 x Intel Atom 1.6 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
4 x 6 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
15
RAM
1 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
24 TB
24 TB
20.3 cm
23.32 cm
16.5 cm
2.03 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
RAM
1 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap - 3.5"
4 x 6 TB
Interface Type
SATA 6Gb/s
Buffer Size
64 MB
Network / Transport Protocol
PPTP, L2TP, PPPoE, LPR/LPD, SMTP, FTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, VPN support, wake on LAN (WOL), Syslog support, print server, MySQL server, backup server, file sharing, Access Control List (ACL) support, SSH support, iTunes server, FTP server, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, e-mail notification
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED
Security DVR
15
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A
1 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, scheduled power on/off
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
External power adapter
41.95 Watt
Power Provided
90 Watt
Software Included
Drivers & Utilities
TAA Compliant
5 °C
35 °C
5 - 95%
Sound Emission
20 dBA
