The DS415+ NAS solution has CPU with an AES-NI hardware encryption engine, a floating-point unit, as well as DDR3 RAM. The drive bays accommodate huge amounts of storage capacity, while the USB 3.0, USB 2.0, and eSATA ports allow users to connect and access a range of external storage devices. Dual LAN ports support failover and link aggregation, thus improving resiliency and potential throughput.
DS415+ supports Synology high availability (SHA), harnessing an active and a passive server into one cluster, mirroring written data between the two units. Should the main server malfunction, the passive server immediately kicks in and takes over all running services and data. Synology Hybrid RAID allows you to optimize usage and get the most out of your hard drives, while also keeping your storage safe with data redundancy.
A powerful and secure box
The DS415+ NAS solution has CPU with an AES-NI hardware encryption engine, a floating-point unit, as well as DDR3 RAM. The drive bays accommodate huge amounts of storage capacity, while the USB 3.0, USB 2.0, and eSATA ports allow users to connect and access a range of external storage devices. Dual LAN ports support failover and link aggregation, thus improving resiliency and potential throughput. -
Excellent performance while safeguarding data
- Synology Disk Station DS415+ - NAS server - 12 TB - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 12 TB
- Max Supported Capacity
- 24 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 20.3 cm x 23.32 cm x 16.5 cm
- 2.05 kg ()
- Processor
- 1 x Intel Atom 2.4 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 4 x 3 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 40
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- TAA Compliant
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 12 TB
- 24 TB
- 20.3 cm
- 23.32 cm
- 16.5 cm
- 2.05 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- RAM
- 2 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 4 x 3 TB
- Interface Type
- SATA 6Gb/s
- Buffer Size
- 64 MB
- Data Link Protocol
- DNS
- Network Services Compatibility
- Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP)
- Wake on LAN (WOL), Syslog support, High Availability, Access Control List (ACL) support, RADIUS support, iTunes server, DNS server, Link Aggregation Control Protocol (LACP), VPN Server
- DLNA CERTIFIED
Security DVR
- 40
- Compression Format
- MJPEG, H.264
- Image Resolution
- 1920x1080, 2048x1536, 1280x800, 2591x1944
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x USB 2.0 - Type A , 1 x eSATA
- Cables Included
- 2 x network cable
- Built-in 2 cooling fans, Citrix Ready, scheduled power on/off, VMware Ready
- FCC Class B certified, RoHS, BSMI Class B
- TAA Compliant
- Power Device
- External power adapter
- Voltage Required
- 46.2 Watt
- Power Provided
- 100 Watt
- Software Included
- iTunes Server, RADIUS Server
- TAA Compliant
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 20.2 dBA
