Synology DS3617xs II 12 Bay Desktop NAS
Quicklinx: GBSNWS00 Mfr#: DS3617xs II
  • Xeon
Meet the 12-bay desktop NAS that allows instant deployment with scalability up to 36 drives, delivering outstanding 2,358 MB/s sequential throughput reading. DS3617xs is certified for VMware, Citrix, Hyper-V, and OpenStack, ready to bring superior agility and efficiency to businesses.
  • Versatile and reliable storage platform
    The DS3617xsII combines high performance with high scalability to deliver a cost-efficient data management solution.
  • Optimized for data protection and integrity
    Synology's DSM operating system and the Btrfs file system work together to safeguard your data with data protection technologies.
  • Remote and on-premises collaboration
    Synology's collaboration suite provides a private cloud solution for on-premises and remote workers to concurrently edit documents, share files, manage e-mails, send instant messages and more. By leveraging private cloud infrastructure, businesses can ensure complete data ownership and multilayered security.
Synology Disk Station DS3617xsII - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 12 (max)
30 cm x 34 cm x 27 cm
9.8 kg ()
1 x Intel Xeon D-1527 2.2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, RAID F1
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
75
RAM
16 GB
AC 100-240 V (50/60 Hz)
Storage Operating System
Synology DiskStation Manager
Microsoft Windows 7 or later, Apple MacOS X 10.12 or later
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
30 cm
34 cm
27 cm
9.8 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.7 GHz
RAM
16 GB (installed) / 48 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, SMTP, FTP, DNS, POP3, IMAP, SMB, NFS, SFTP, HTTP, HTTPs
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH, SFTP
Network Services Compatibility
Microsoft Active Directory (AD), DNS, File Level Security (ACLs), Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV), SFTP, Server Message Block 2.0 (SMB 2.0), Server Message Block 3.0 (SMB 3.0), Network File System v3 (NFS v3), Network File System v4 (NFS v4), Network File System v4.1 (NFS v4.1)
Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), High Availability, backup server, download client, file sharing, event log, Access Control List (ACL) support, RADIUS support, iTunes server, FTP server, reset button, bandwidth control, surveillance station, PXE support, DNS server, DLNA Media Server, Apple Time Machine compatible, e-mail notification, cloud backup, VPN Server, Dropbox support, anti-virus protection, Link Aggregation, Photo album server, Google Drive support, Yandex Disk support, Microsoft OneDrive support, OpenStack compatible, file station, hubiC support, OpenStack Swift-compatible, WebDAV server support, Baidu cloud support, cloud station server, MailPlus server, Amazon S3 support, Rsync compatible, Alibaba Cloud OSS support, Backblaze B2 support, MegaDisk support, Tencent COS support
Encryption Algorithm
SSL, TLS, AES-NI
Security DVR
75
Compression Format
MJPEG, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x8 , 4 (total) / 2 (free) x SO-DIMM 260-pin
2 x USB 3.2 Gen 1 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 1 x serial (management) - DB-9 , 2 x InfiniBand
2 x network cable
Wake on LAN, lockable, built-in 2 cooling fans, scheduled power on/off, reset button
VCCI, BSMI, FCC, RoHS, KC, EAC, RCM
Accessory pack
Internal power supply
Power Provided
550 Watt
Software Included
McAfee AntiVirus (Trial)
Limited warranty - 5 years
5 °C
5 - 95% RH
