Synology DS3617xs 2U 12 bay Rackmount NAS Enclosure
Quicklinx: CL28WS00 Mfr#: DS3617XS
  • Xeon
£1,947.42 ex VAT
£2,336.90 inc VAT
Meet the 12-bay desktop NAS that allows instant deployment with scalability up to 36 drives, delivering outstanding 2,358MB/s sequential throughput reading. DS3617xs is certified for VMware, Citrix, Hyper-V, and OpenStack, ready to bring superior agility and efficiency to businesses.
High-performance NAS server for RAM-intensive applications
Equipped with an Intel Xeon-D quad-core processor, DS3617xs delivers stunning performance with over 2,358 MB/s reading under a RAID 5 configuration with optional 10GbE and Link Aggregation enabled. Initially equipped with 16GB DDR4 ECC RAM (upgradable to 48GB), it ensures data accuracy when handling high-value data and mission-critical tasks.
Scale on demand
DS3617xs can be connected to one or two dedicated DX1215 expansion units, allowing you to expand storage capacity to up to 36 drives without disrupting service. The high-bandwidth cable ensures instant and lossless connections between the main server and the expansion units.
10GbE upgradability
In addition to the four built-in Gigabit ports, DS3617xs comes with a PCIe 3.0 x8 slot to support an optional 10GbE Network Interface Card (NIC), maximizing bandwidth and meeting high performance requirements for data-intensive applications.
Reliable redundancy mechanisms
DS3617xs comes with comprehensive redundancy mechanisms to ensure business continuity. Built-in four LAN ports with failover provides reliable redundancy in the event of unexpected network failure. The high reliability system design, including fanless CPU heat-sink and passive cooling technologies, prevents a single point of failure.
5 year warranty
Synology DS3617xs is backed with Synology's 5-year limited warranty. With technical support and hardware replacement service, the 5-year warranty maximizes your enterprises' return on investment.
Synology Replacement Service (SRS)
The Synology Replacement Service (SRS) provides free shipment of replacement units as early as the next business day. SRS can expedite the process of replacing defective products and minimize service downtime.
  • High-performance NAS server for RAM-intensive applications
    Equipped with an Intel Xeon-D quad-core processor, DS3617xs delivers stunning performance with over 2,358 MB/s reading under a RAID 5 configuration with optional 10 GbE and Link Aggregation enabled. Initially equipped with 16 GB DDR4 ECC RAM, it ensures data accuracy when handling high-value data and mission-critical tasks.
  • 10 GbE upgradability
    In addition to the four built-in Gigabit ports, DS3617xs comes with a PCIe 3.0 x8 slot to support 10 GbE Network Interface Card (NIC), maximizing bandwidth and meeting high performance requirements for data-intensive applications.
  • Reliable redundancy mechanisms
  • Protection with LUN backup, snapshot, and clone
    DS3617xs enhances the ease of moving and copying data in a virtualized environment with the features LUN Snapshot, clone, and replication. Synology's LUN Clone and LUN Snapshot only consume 1/1000 of the original size highly optimizing storage usage. In addition, Synology's LUN Snapshot lets you create up 256 snapshots per LUN using point-in-time technology without having any impact on system performance. With better support to servers under VMware vSphere or Windows environment, IT managers can expect guaranteed VM status and data consistency through application-consistent snapshots.
  • Ensuring business continuity & reliability
    Uninterrupted availability is a critical goal for all businesses. DS3617xs offers Synology High Availability (SHA) technology which combines an active and passive server into one cluster, the former always mirrored to the latter. Shared Folder Sync can replicate data in real-time to another Synology NAS at a remote location, giving your business the Recovery Time Objective (RTO) for prompt disaster recovery. With multiple LAN ports, DS3617xs also ensures redundancy in the event of unexpected network failure.
Synology Disk Station DS3617xs - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
120 TB
0 (installed) / 12 (max)
30 cm x 34 cm x 27 cm
9.8 kg ()
1 x Intel Xeon D-1527 2.2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
75
RAM
16 GB
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
120 TB
30 cm
34 cm
27 cm
9.8 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
16 GB (installed) / 48 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Network / Transport Protocol
iSCSI
Network Services Compatibility
File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP)
WOL, ACL support, DLNA support
Security DVR
75
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x8
2 x USB 3.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45
2 x network cable
Built-in 2 cooling fans
FCC Class B certified, RoHS, BSMI Class B
Internal power supply
Power Provided
500 watt
Limited warranty - 5 years
5 °C
5 - 95% (non-condensing)
Sound Emission
22.3 dBA
Brand: Synology
Price Range Ex VAT: £1500+
