Synology DS2419+II 12 Bay Desktop NAS
Quicklinx: GBSPWS00 Mfr#: DS2419+II
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
Capacity: 0GB
  • Atom
£1,226.98 ex VAT
£1,472.37 inc VAT
Synology DiskStation DS2419+II is a cost-effective 12-bay desktop NAS with file management, file sharing, and backup capabilities. Specifically designed for small to medium-sized businesses and remote office deployments, the unit is powered by Synology’s DiskStation Manager (DSM), that includes essential business software solutions. For added performance, it can be expanded with 12 additional drive bays, NVMe SSD cache, and 10GbE networking.
  • Snapshot Replication
    Snapshot Replication enables flexible point-in-time snapshots of shared folders and virtual machines with an RPO as low as 5 minutes and recovery within seconds.
  • Get your business ready for remote work
    Enable your workforce to go remote by leveraging Synology's out-of-the-box solutions for collaboration, file sharing, and communication.
  • Flexible expansion options
    The DS2419+II is easily upgradable and adaptable to any application.
  • Serve more users
    Support for 10/25GbE NICs lets you boost maximum network throughput.
Synology Disk Station DS2419+II - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 12 (max)
30 cm x 34 cm x 27 cm
9.5 kg ()
1 x Intel Atom C3538 2.1 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
40
RAM
4 GB
AC 100-240 V (50/60 Hz)
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
30 cm
34 cm
27 cm
9.5 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 32 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
L2TP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV), Server Message Block 2.0 (SMB 2.0), Server Message Block 3.0 (SMB 3.0), Network File System v3 (NFS v3), Network File System v4 (NFS v4), Network File System v4.1 (NFS v4.1)
Firewall protection, hardware encryption, wake on LAN (WOL), High Availability, event log, FTP server, surveillance station, DLNA Media Server, 4K resolution support, cloud backup, VPN Server, file station, snapshot (folder and LUN), wake on WAN (WOW)
Encryption Algorithm
SSL, TLS, AES-NI
Security DVR
40
Compression Format
MJPEG, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x PCI Express 3.0 x8
2 x USB 3.2 Gen 1 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 1 x management - DB-9 , 1 x expansion port
2 x network cable
Built-in 2 cooling fans
VCCI, BSMI, CCC, FCC, RoHS, KC, EAC, RCM
Accessory pack
Internal power supply
101.6 Watt
Power Provided
550 Watt
Limited warranty - 3 years
5 - 95%
Sound Emission
22.3 dBA
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Capacity: 0GB
Brand: Synology
Price Range Ex VAT: £1000 - £1500
