Synology DS220+ 2 Bay NAS
Quicklinx: FWMXWS00 Mfr#: DS220+
  • Celeron
Synology DiskStation DS220+ is a compact network-attached storage solution to streamline your data and multimedia management. It features smooth data sharing, video streaming, and photo indexing, as well as well-rounded data protection and recovery options.
  • Accelerated application performance
    Enjoy the performance boost to photo indexing and other computing-intensive operations, as well as database response time.
  • Effortless data sharing and synchronization
    Access, share, and sync your data easily across different operating systems and devices.
  • Protect and restore data in a snap
    Back up critical data and reduce your Recovery Time Objective (RTO) with Snapshot Replication.
  • Entertaining multimedia hub
    Organize and stream your music, video, and photo collections across all your devices.
  • Streamline your data management experience
    DS220+ is a 2-bay desktop NAS designed for fast data sharing and management. It features dual 1GbE LAN ports to support network failover, and is link aggregation enabled.
  • Advanced snapshot technology
    Advanced snapshot technology provides schedulable and near-instantaneous data protection of shared folders and LUNs.
  • File and folder level data restoration
    File and folder level data restoration offers users who wish to restore only a specific file or folder more flexibility.
  • Inline compression
    Inline compression compresses data before writing them to the drive, to optimize storage use and reduce write commands to the drives.
Synology Disk Station DS220+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
32 TB
0 (installed) / 2 (max)
10.8 cm x 23.22 cm x 16.5 cm
1.3 kg ()
1 x Intel Celeron J4025 2 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, JBOD
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
25
RAM
2 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
32 TB
10.8 cm
23.22 cm
16.5 cm
1.3 kg ()
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Turbo Speed
2.9 GHz
RAM
2 GB (installed) / 6 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DNS, POP3, IMAP, SMB, DDNS, NFS
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH, LDAP, RADIUS
Network Services Compatibility
Microsoft Active Directory (AD), DNS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, VPN support, LDAP support, WOL, antivirus analysis, High Availability, file sharing, ACL support, RADIUS support, SSH support, iTunes server, Samba support, FTP server, reset button, bandwidth control, surveillance station, PXE support, DNS server, Apple Time Machine compatible, cloud backup, VPN Server, anti-virus protection, scheduler, 1 fan, file station
Encryption Algorithm
AES-NI
Security DVR
25
Compression Format
H.264
Expansion Bays
2 (total) / 2 (free) x hot-swap - 2.5" / 3.5"
2 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
2 x network cable
Security lock slot (cable lock sold separately), RADIUS support
Security Slot Type
Kensington security slot
VCCI, BSMI, CCC, FCC, RoHS, KC, EAC, RCM
Accessory pack
External power adapter
14.69 watt
Power Provided
60 watt
5 - 95%
Sound Emission
19.3 dBA
