Synology DS216/12TB-RED 2 Bay NAS
Quicklinx: C28KWS00 Mfr#: DS216/12TB-RED
Featuring an advanced processing unit with AES-NI hardware encryption engine, Btrfs file system support, and 4K UHD transcoding, DS216+ is a high-performance 2-bay NAS server aimed at small office and home users who want an efficient and secure storage solution to protect and share data, as well as enjoy on-the-fly video transcoding.
  • Dual-core CPU with floating-point unit enhances productivity
    DS216 delivers outstanding read/write performance with an average over 111 MB/s reading and writing speeds under RAID 1 configuration in a Windows environment. The built-in floating-point unit enhances the overall capability of the main CPU, and is particularly advantageous in speeding up thumbnail creation when uploading large amounts of photos or videos.
  • Hardware encryption engine enhances file transfer speeds
    DS216 is equipped with an encryption engine which offloads encryption calculation tasks away from the main CPU. Thus, the CPU can be free for other important tasks. DS216, compared with its predecessor DS214, has a 50% increase in encryption reading speed and an over 110% increase in encryption writing speed.
  • Easy installation, hassle-free maintenance
    Hot-swappable drive trays support and easy installation ensure easy maintenance and continuous service uptime should a hard drive need replacement. In addition, DS216 introduces a USB copy button for easy data transmission.
  • USB 3.0 ensures speedy transfers to external storage
    DS216 boasts USB 3.0 to connect to various kinds of external storage devices, while ensuring fast and efficient file transfer speeds. USB 3.0 support offers transfer speeds of up to 5 Gbps (about 10 times faster than USB 2.0), meaning less time needed to transfer data to external hard drives while consuming less power.
  • Thoughtful four-level brightness control for front LEDs
    Equipped with adjustable LED indicators, DS216's front LEDs can provide comfortable brightness by controlling and scheduling its four-stage brightness, letting you flexibly decide the intensity of the front LEDs according to environment needs.
Synology Disk Station DS216 - NAS server - 12 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
12 TB
Max Supported Capacity
16 TB
2 (installed) / 2 (max)
10.8 cm x 23.32 cm x 16.5 cm
1.3 kg ()
1 x Marvell ARMADA 88F6820 1.3 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, JBOD
Hard Drive
2 x 6 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
16
RAM
512 MB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.7 or later, Ubuntu 12.x, Android 4.0 or later, Apple iOS 7 or later
NAS server
Host Connectivity
Gigabit Ethernet
12 TB
16 TB
10.8 cm
23.32 cm
16.5 cm
1.3 kg ()
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
512 MB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 6 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
PPTP, L2TP, SMTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, wake on LAN (WOL), download client, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, reset button, bandwidth control, surveillance station, VPN Server, automated backup scheduling, Wi-Fi USB dongle support
DLNA CERTIFIED, UPnP
Security DVR
16
Expansion Bays
2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
2 x USB 3.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption
Security Slot Type
Kensington security slot
FCC Class B certified, RoHS, BSMI Class B
External power adapter
Software Included
Drivers & Utilities
5 °C
5 - 95%
