Synology DS216+/20TB (2x10TB Seagate NAS HDD) 2 Bay NAS
Quicklinx: CB6JWS00 Mfr#: DS216+/20TB-S
  • Celeron
Featuring an advanced processing unit with AES-NI hardware encryption engine, Btrfs file system support, and 4K UHD transcoding, DS216+ is a high-performance 2-bay NAS server aimed at small office and home users who want an efficient and secure storage solution to protect and share data, as well as enjoy on-the-fly video transcoding.
  • High-speed data transfer and hardware encryption engine
    Equipped with a powerful processor and AES-NI hardware encryption engine, DS216+ delivers blazingly fast file transfer speeds - even when handling encrypted data. DS216+ delivers high-speed performance, while ensuring encrypted data transmissions.
  • Easy installation, hassle-free maintenance
    For friendly and effortless hard drive installation, DS216+ features a screwless drive bay design and hot-swappable support, allowing users to install hard drives without a screwdriver. Installing and replacing drives is easier than ever.
  • Thoughtful four-level brightness control for front LEDs
    DS216+ comes with adjustable front LED indicators, allowing you to choose between four levels of brightness and set a schedule according to time and day. That way, you can achieve comfortable and appropriate brightness level for your individual environment.
  • 4K Ultra HD video transcoding
    Powered by a hardware-accelerated transcoding engine, DS216+ allows you to transcode H.264 4K videos to 1080p and stream them to high-definition TVs, digital media players, mobile handsets, and computers in the required format.
  • Seamless sharing
    Enjoy seamless files sharing as DS216+ offers comprehensive network protocol support including FTP, SMB2, AFP, NFS and more. DS216+ can fit effortlessly into any existing network environment - there is no need for IT administrators to maintain two sets of credentials. You also won't worry about missing files with the Recycle Bin feature. All files deleted in a shared folder will be automatically moved into the Recycle Bin.
  • Effective backup solution
    Synology DS216+ can serve as a centralized backup target. Whenever you modify a file, the changes are backed up to DS216+ automatically. You can also back up data from your DS216+ to external drives, cloud services, and more. Backup & replication allow you to schedule backup tasks and restore the server to any particular point in time, while minimizing storage consumption and processing time by saving only the specific data block that has been changed between versions.
  • Secure your data
    DS216+ offers advanced security measures to protect you from potential security holes. Security Advisor analyzes system settings, password strength, network preferences and removes any possible malware. AppArmor blocks malicious programs from accessing unauthorized system resources. In addition, DS216+ provides other security add-ons, such as AES encryption, advanced verification, IP block & allow list, antivirus packages, firewall, and DoS attack prevention.
  • Eco-friendly NAS server
    All Synology NAS is designed with energy efficiency in mind. With special fan and the smart airflow design, the DS216+ keeps the system running cool 24/7, while its noise dampening design makes it quieter than PC counterparts.
Synology Disk Station DS216+ - NAS server - 20 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
20 TB
2 (installed) / 2 (max)
10.8 cm x 23.32 cm x 16.5 cm
1.25 kg ()
1 x Intel Celeron N3050 1.6 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s / eSATA 6Gb/s RAID RAID 0, 1, JBOD
Hard Drive
2 x 10 TB
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
25
RAM
1 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.7 or later, Ubuntu 12.x, Android 4.0 or later, Apple iOS 7 or later
NAS server
Host Connectivity
Gigabit Ethernet
20 TB
10.8 cm
23.32 cm
16.5 cm
1.25 kg ()
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB DDR3
Storage Controller
RAID
Interface Type
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 10 TB
Network / Transport Protocol
PPTP, L2TP, SMTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, wake on LAN (WOL), download client, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, reset button, bandwidth control, surveillance station, VPN Server, automated backup scheduling, Wi-Fi USB dongle support
Encryption Algorithm
AES, SSL
DLNA CERTIFIED, UPnP
Security DVR
25
Compression Format
MPEG-2, H.264
Image Resolution
4096 x 2160
Frame Rate
30 fps (playback)
Expansion Bays
2 (total) / 0 (free) x internal - 2.5" / 3.5"
1 x USB 3.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 1 x eSATA 6Gb/s
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption, 24x7 continuous operation, fan speed controller
Security Slot Type
Kensington security slot
FCC Class B certified, RoHS, BSMI Class B, TLS
External power adapter
Power Provided
60 Watt
Software Included
Drivers & Utilities
5 °C
5 - 95%
