Synology DS214se DiskStation 2-Bay Desktop NAS
Quicklinx: 92X2WS00 Mfr#: DS214SE
Synology® DiskStation DS214se is a budget-friendly two-bay NAS device with the capability to host, share and protect data
  • 102 MB/s Reading, 58 MB/s Writing
  • DLNA®-Certified Media Server
  • 19W Low Power Consumption
  • Hassle-free System Installation
  • Running on Synology DiskStation Manager (DSM)
Sharing the variety of packages in DSM Package Center, DS214se helps beginners explore the infinite possibilities of Synology NAS.
Choice NAS for Everyone
Centering on the core features of NAS devices, Synology DS214se provides handy and effective network storage under budget. Not only does DS214se centralize and back up your digital contents, it makes cross-platform and cross-device sharing effortless. DS214se delivers an average over 58 MB/sec writing speed under RAID 1 configuration in a Windows® environment, and over 102 MB/sec reading.1 Equipped with Synology's full multimedia applications, DS214se is also an ideal solution for users looking for entertainment and download center, providing easy and energy-efficient download service as well as multimedia streaming capabilities. With Synology's rich cloud applications, DS214se serves as your personal cloud whose content is available anywhere on demand.
Easy Setup and Management
Web Assistant is a web-based utility to make every DiskStation as easy to install as possible. Installation is done inside your existing web browser by setting up all vital system components in few simple steps. Combined with a quick start widget, users can simultaneously tour the DSM operating system and set it up to use right away. For users unfamiliar with complicated router configurations or those who simply want to save time, the Synology EZ-Internet Wizard simplifies the process of setting up access to the Synology DS214se from the Internet. EZ-Internet Wizard walks you through all of network settings including firewall, port-forwarding, PPPoE setup and DDNS registration. The multi-tasking web UI on DSM allows users to run multiple applications simultaneously on one tab browser and switch between them instantly. Synology Hybrid RAID allows you to reach maximum use of your hard drive while keeping your storage safe with data redundancy.
24/7 Download Portal
Feed your data-appetite with Download Station, your 24/7 download portal. With its comprehensive built-in BT search engine, you can locate your desired files in just a few clicks. So turn off your PC and let your DS214se download all your content directly to your centralized storage. With DS download on iPhone® and Android™, you can manage download tasks even while on the go.
Certified DLNA Media Server
As a fully certified DLNA DMS (Digital Media Server), DS214se serves also as a ready media server with the capability to host digital multimedia contents for remote playback. Once connected to a wireless router, DS214se is set to stream music, photos and videos to DLNA-compliant devices without any pre-configuration, thus enabling users to enjoy their collection on larger screens or with quality speakers. Synology even makes it possible for users to browse and select DiskStation contents using DS audio - a handy mobile app - to designate a DLNA player within the same local network to play it.
Anywhere/Anytime Availability
QuickConnect and EZ-Internet configure your DS214se for accessing over the Internet with minimal effort. Cloud Station allows users to sync files among multiple devices, including Windows PC, Mac®, Linux®, iOS and Android tablets or phones, effortlessly keeping everything up-to-date. Combined with Synology's mobile apps for every popular feature, including DS photo+, DS audio, and DS video for anywhere multimedia access, DS download, DS file, and DS cloud for seamless file download/access/synchronization, DS cam for home security, you can enjoy your NAS anywhere, any time.
Synology DiskStation Manager (DSM) is a web-based OS that provides private cloud service. It is designed to make your everyday living easier. The built-in Package Center allows you to download and install the packages designed specifically for your unique needs, whether it's sharing files on the cloud, sharing photos on an online album, setting up a VPN environment or even an antivirus to protect your system. All will happen with just a few clicks. The simple interface allows you to obtain and configure storage capacity with minimal friction. It provides you with complete control of your personal cloud and lets you access it anywhere. Synology DSM will help you maximize productivity and get more out of your digital assets with minimal fuss.
Energy Efficient with Cool and Quiet Design
Synology DS214se is designed with energy efficiency in mind. Not only does it provide a larger fan and the smart airflow to keep the system running cool 24/7, its noise dampening design makes it really quiet compared to PC counterparts. The hard drive hibernation can further reduce power consumption and operation cost. All Synology products are produced with RoHS compliant parts and packed with recyclable packing materials. Synology acknowledges the responsibility as a global citizen to continually work to reduce the environmental impact of every product produced.
Hardware Specification
  • CPU Frequency 800MHz
  • Hardware Encryption Engine Yes
  • Memory DDR3 256MB
  • Internal HDD/SSD 3.5" or 2.5" SATA(II) x 2 (hard drives not included)
  • Max Internal Capacity 8TB (2 x 4TB hard drive) (The actual capacity will differ according to volume types.)
  • External Device Interface USB 2.0 port x 2
  • Size (H x W x D) 165mm x 100mm x 225.5mm
  • Weight 870g
  • LAN Gigabit x 1
  • Wireless Support Yes (wireless dongles not included)
  • AC Input Power Voltage 100V to 240V
  • Power Frequency 50Hz to 60Hz, Single Phase
  • Operating Temperature 5°C to 35°C (40°F to 95°F)
  • Storage Temperature -10°C to 70°C (15°F to 155°F)
  • Relative Humidity 5% to 95%RH
Package Contents
  • DS214se Main Unit
  • Welcome Note
  • Accessory Pack
  • AC Power Cord
  • AC Power Adapter
  • RJ-45 LAN Cable
  • Choice NAS for everyone
    Centering on the core features of NAS devices, Synology DS214se provides handy and effective network storage under budget. Not only does DS214se centralize and back up your digital contents, it makes cross-platform and cross-device sharing effortless. The built-in floating-point unit enhances the overall capability of the main CPU, and is particularly advantageous in speeding up thumbnail processing, making photo viewing a refreshing experience. Equipped with Synology's full multimedia applications, DS214se is also an ideal solution for users looking for entertainment and download center, providing easy and energy-efficient download service as well as multimedia streaming capabilities. With Synology's rich cloud applications, DS214se serves as your personal cloud whose content is available anywhere on demand.
  • Easy setup and management
  • 24/7 download portal
  • Certified DLNA media server
  • Anywhere/anytime availability
    QuickConnect and EZ-Internet configure your DS214se for accessing over the Internet with minimal effort. Cloud Station allows users to sync files among multiple devices, effortlessly keeping everything up-to-date. Combined with Synology's mobile apps for every popular feature, including DS photo+, DS audio, and DS video for anywhere multimedia access, DS download, DS file, and DS cloud for seamless file download/access/synchronization, DS cam for home security, you can enjoy your NAS anywhere, any time.
  • Energy efficient with cool and quiet design
Synology Disk Station DS214se - NAS server - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
16 TB
0 (installed) / 2 (max)
10 cm x 22.55 cm x 16.5 cm
870 g ()
1 x 800 MHz
Storage Controller
SATA SATA 3Gb/s
Hard Drive
Standard
Network adapter 10Mb LAN, 100Mb LAN, 1GbE
RAM
256 MB
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
16 TB
10 cm
22.55 cm
16.5 cm
870 g ()
Processor / Memory
Processors Installed
1 x 800 MHz
RAM
256 MB DDR3
Storage Controller
SATA
Interface Type
SATA 3Gb/s
Hard Drive
Standard - 2.5" / 3.5" shared
Network adapter
Network / Transport Protocol
TCP/IP, PPTP, PPPoE, iSCSI, LPR/LPD, SMTP, FTP, DHCP, POP3, IMAP, DDNS
Remote Management Protocol
SNMP, Telnet, IPP, HTTP, HTTPS, SSH
Network Services Compatibility
DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
Firewall protection, VPN support, LDAP support, VLAN support, Syslog support, E-mail alert, print server, IPv6 support, MySQL server, web server, backup server, download client, file sharing, ACL support, ADS, SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, eMule client, e-mail notification, VPN Server
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Expansion Bays
2 (total) / 2 (free) x hot-swap - 2.5" / 3.5"
2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
1 x network cable
Built-in cooling fan, hardware encryption
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
External power adapter
TAA Compliant
5 °C
35 °C
5 - 95%
92X2 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
