Synology DS214 PLAY 8TB 2-Bay Desktop NAS
Quicklinx: 92SYWS00 Mfr#: DS214PLAY/8TB-RED
Synology DiskStation DS214play is a two-bay NAS designed to serve as your ultimate media center. Optimized for multimedia processing, DS214play aims to fulfill increasing need for high-quality photo, music and video streaming, while keeping all other aspects of NAS uncompromised.
  • Ultimate entertainment center
    Synology DS214play is a ready media server specifically designed for users to enjoy maximized fun on their NAS device. The built-in floating-point unit not only enhances the overall capability of the main CPU but shows particular advantage in speeding up thumbnail processing, making photo viewing on DS214play a refreshingly experience. Now video station and DS video users can enjoy on-demand high-quality video transcoding offered exclusively by DS214play.
  • Personal multimedia bank
    Photo station's intuitive design allows you to effortlessly organize photos into customized categories, smart albums and blog posts, and link them to social networking websites like Facebook, Twitter, Plurk and Picasa within a few clicks. Audio station comes with built-in lyrics plug-in, Internet radio, and support for DLNA, AirPlay, and Bluetooth speakers for quality playback. With Video Station, you can watch movies and TV shows online or record your favorite programs with a DVB-T/DVB-S stick.
  • Versatile storage server
    DS214play also comes with comprehensive external storage integration, providing two SuperSpeed USB 3.0 and one eSATA interfaces in the back, one SD card and one USB 2.0 interface in the front panel, along with the copy button that enables one-click data replication from your SD/USB device to DS214play. Designed with both safety and convenience in mind, DS214play contains the tool-less hard drive trays, allowing users to fixate 3.5" hard drives without screws and drivers. Meanwhile, DS214play supports hot-swappable hard drive trays for instant and risk-free hard disk replacement.
  • Anywhere/anytime availability
    Synology provides mobile applications that allow you to enjoy the full variety of your multimedia library even when on the go, allowing you to reach for your private albums, music and video collection at home in DS214play. What's more, DS download makes it possible for you to manage and monitor your download tasks remotely while you can access DS214play content with DS file whenever required.
  • DLNA ready media server
    As a ready DLNA DMS (Digital Media Server), DS214play serves also as a ready media server with the capability to host digital multimedia contents for remote playback. Once connected to a wireless router, DS214play is set to stream music, photos and videos to DLNA-compliant devices without any pre-configuration, thus enabling users to enjoy their collection on larger screens or with quality speakers.
  • Easy setup and management
    Combined with a quick start widget, users can simultaneously tour the DSM operating system and set it up to use right away. For users unfamiliar with complicated router configurations or those who simply want to save time, the Synology EZ-Internet Wizard simplifies the process of setting up access to the Synology DS214play from the Internet. EZ-Internet Wizard walks you through all of network settings including firewall, port-forwarding, PPPoE setup and DDNS registration. The multi-tasking web UI on DSM allows users to run multiple applications simultaneously on one tab browser and switch between them instantly. Synology Hybrid RAID allows you to reach maximum use of your hard drive while keeping your storage safe with data redundancy.
  • Energy efficient with cool and quiet design
    Synology DS214play is designed with energy efficiency in mind. Not only does it provide a larger fan and the smart airflow to keep the system running cool 24/7, its noise dampening design makes it really quiet compared to PC counterparts. The hard drive hibernation can further reduce power consumption and operation cost.
Synology Disk Station DS214play - NAS server - 8 TB - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
8 TB
Max Supported Capacity
8 TB
2 (installed) / 2 (max)
10.8 cm x 23.32 cm x 16.5 cm
1.265 kg ()
1 x 1.6 GHz (Dual-Core)
Storage Controller
SATA SATA 6Gb/s
Hard Drive
2 x 4 TB
Card Reader
Network adapter 10Mb LAN, 100Mb LAN, GigE
RAM
1 GB
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
8 TB
8 TB
10.8 cm
23.32 cm
16.5 cm
1.265 kg ()
Processor / Memory
Processors Installed
1 x 1.6 GHz
Number of Cores
Dual-Core
RAM
1 GB DDR3
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Hard Drive
HDD - hot-swap
2 x 4 TB
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Network adapter
Network / Transport Protocol
TCP/IP, PPTP, PPPoE, iSCSI, LPR/LPD, SMTP, FTP, DHCP, POP3, IMAP, DDNS
Remote Management Protocol
SNMP, Telnet, IPP, HTTP, HTTPS, SSH
Network Services Compatibility
DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
Firewall protection, VPN support, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, Advanced Data Streaming (ADS), SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, eMule client, e-mail notification, VPN Server
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Expansion Bays
2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
1 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x eSATA , 1 x Ethernet 1000Base-T - RJ-45
1 x network cable
Built-in cooling fan, hardware encryption
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
External power adapter
28.74 Watt
Power Provided
65 Watt
TAA Compliant
5 °C
35 °C
5 - 95% (non-condensing)
