Synology DS213J 2-Bay Desktop NAS
YOUR OWN CLOUD ENTERTAINMENT STARTS HERE!
Quicklinx: 8PNZWS00 Mfr#: DS213J
DS213j: Your Own Cloud Entertainment Starts Here
Synology® DiskStation DS213j is a budget-friendly 2-bay NAS server for small offices and home use, specifically designed to provide a solution for file storage and sharing with data protection for your home environment with low power consumption, quiet operation and reliability. Running on DiskStation Manager (DSM) operating system, it delivers ease of use and variety of features.
  • Floating-Point Unit Enabled CPU Favored Multimedia Processing
  • Large 512MB RAM for Multitasking
  • Over 100MB/sec Reading, 70MB/sec Writing
  • Wake on LAN Ready
  • Cool and Quiet Chassis
  • DLNA® Compliant Media Server
  • Running on Synology DiskStation Manager
High-Performance Multimedia Processing with Smart Energy Management
With a RAID 1 configuration in a Windows® environment, Synology DS213j delivers read and write speeds of over 100MB/sec and 70MB/sec respectively, allowing you to share an entire Blu-ray quality video in less than 3 minutes. The built-in Floating-Point Unit CPU speeds up thumbnail processing to enhance photo viewing at different resolutions, while the large 512MB RAM ensures maximum speed when running multiple multimedia applications.
Synology DS213j is designed with energy efficiency in mind. Not only does it provide a large 92mm fan and smart airflow to keep the system running cool 24/7, but its noise dampening design makes it quiet compared to a public space in a library. Support for Wake on LAN/WAN, multiple scheduled power on/off, and hard drive hibernation can further reduce power consumption and operating costs.
Your Data is Safe with Synology
DS213j with Synology Hybrid RAID helps you balance storage capacity and data redundancy so you can have your space and use it too (custom RAID configuration available for advanced users). Your DS213j is also the ideal one-stop centralized backup solution: from PCs to NAS, NAS to NAS, NAS to peripheral storage media (such as USB stick) or NAS to remote storage via a whole host of options.
24/7 Download Portal
Feed your data-appetite with Download Station, your 24/7 download portal. With its comprehensive built-in BT search engine, you can find and download files in just a few clicks. So turn off your PC and let your DS213j download all your content directly to your centralized storage. With DS download on iPhone® and Android™, you can manage download tasks even while on the go.
Personal Entertainment Center
Enjoy multimedia easily with Audio Station, and Video Station. Find movies and TV shows online or record your favorite programs with a DVB-T stick, and play them on all devices including Windows, Mac®, DLNA, AirPlay®, Bluetooth, iOS, Android, and Windows Phone.
Take photos on your mobile device and let Instant Upload automatically send them to your DiskStation so they are ready for sharing through Photo Station or social networks including Facebook, Twitter, Plurk and Picasa.
Anywhere/Anytime Availability
QuickConnect and EZ-Internet configure your DS213j for accessing over the Internet with minimal effort. Combined with Synology's mobile apps for every popular feature, including DS photo+, DS audio, and DS video for anywhere multimedia access, DS download, DS file, and DS cloud for seamless file download/access/synchronization, DS cam for home security, you can enjoy your NAS anywhere, any time.
Powered by Synology DSM
Synology DiskStation Manager (DSM) is a web-based OS that provides private cloud service. It is designed to make your everyday living easier.
The built-in Package Center allows you to download and install the packages designed specifically for your unique needs, whether it's sharing files on the cloud, sharing photos on an online album, setting up a VPN environment or even an antivirus to protect your system. All will happen with just a few clicks.
The simple interface allows you to obtain and configure storage capacity with minimal friction. It provides you with complete control of your personal cloud and lets you access it anywhere. Synology DSM will help you maximize productivity and get more out of your digital assets with minimal fuss.
Hardware Specifications
  • CPU Frequency : 1.2GHz
  • Floating Point
  • Hardware Encryption Engine
  • Memory : DDR3 512MB
  • Internal HDD/SSD : 3.5" or 2.5" SATA(II) X 2 (Hard drive not included)
  • Max Internal Capacity : 8TB (2X 4TB HDD) (Capacity may vary by RAID types) (See All Supported HDD)
  • External HDD Interface : USB 2.0 Port X 2
  • Size (HxWxD) : 165 X 100 X 225.5 mm
  • Weight : 0.91Kg
  • LAN : Gigabit X1
  • Wake on LAN/WAN
  • System Fan : 92x92mm X1
  • Easy Replacement System Fan
  • Wireless Support (dongle)
  • Noise Level : 17 dB(A)
  • Power Recovery
  • AC Input Power Voltage : 100V to 240V AC
  • Power Frequency : 50/60 Hz, Single Phase
  • Power Consumption : 19.82W (Access); 3.65W (HDD Hibernation);
  • Operating Temperature : 15°C to 35°C (40°F to 95°F)
  • Storage Temperature : -10°C to 70°C (15°F to 155°F)
  • Relative Humidity : 5% to 95% RH
  • Maximum Operating Altitude : 6,500 feet
  • Certification : FCC Class B, CE Class B, BSMI Class B
  • Warranty : 2 Years
  • Efficient storage management
    The Synology Disk Station DS213J offers flexible storage options with support for RAID 0, RAID 1, and JBOD configurations, allowing users to optimize data protection and performance according to their needs.
  • Comprehensive network compatibility
    With support for a wide range of network protocols including Ethernet, Fast Ethernet, and Gigabit Ethernet, alongside DDNS, FTP, PPPoE, TCP/IP, and iSCSI, this NAS server ensures seamless integration into virtually any network environment.
  • Versatile server capabilities
    This device goes beyond simple storage with features like a backup server, download client, email server, iTunes server, print server, and surveillance station, making it a multifunctional solution for home or office.
  • Advanced security features
    Equipped with SSL and TLS encryption algorithms, alongside firewall protection and Access Control List (ACL) support, the DS213J provides a secure data storage and transmission environment.
  • Energy-efficient operation
    With a power consumption of only 19.82 watts during operation and features like wake on LAN, the Synology Disk Station DS213J is designed for energy-efficient performance without sacrificing functionality.
Synology Disk Station DS213J - NAS server - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
8 TB
0 (installed) / 2 (max)
10 cm x 22.55 cm x 16.5 cm
910 g ()
1 x 1.2 GHz
Storage Controller
RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
Hard Drive
SATA 3Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
RAM
512 MB
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
8 TB
10 cm
22.55 cm
16.5 cm
910 g ()
Processor / Memory
Processors Installed
1 x 1.2 GHz
RAM
512 MB DDR3
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - 2.5" / 3.5" shared
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP, PPPoE, iSCSI, SMTP, FTP, POP3, IMAP, DDNS
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, Web-based Distributed Authoring and Versioning (WebDAV)
Firewall protection, Syslog support, E-mail alert, print server, IPv6 support, IP address filtering, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, Advanced Data Streaming (ADS), iTunes server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, eMule client, e-mail notification
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Expansion Bays
2 (total) / 2 (free) x internal - 2.5" / 3.5"
2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
1 x network cable
Wake on LAN
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
External power adapter
19.82 Watt
Software Included
Synology Assistant, Synology Data Replicator
TAA Compliant
15 °C
35 °C
5 - 95%
Sound Emission
17 dBA
