Synology DS1821+ 8-Bay NAS - Diskless
Quicklinx: G2Y2WS00 Mfr#: DS1821+
Interface: Ethernet, Gigabit Ethernet, Fast Ethernet
Capacity: 0GB
Type: 8-Bay
15 In Stock
£902.25 ex VAT
£1,082.70 inc VAT
Standard delivery Delivered within 3-5 working days
Designed for scalability and performance
The 8-bay Synology DS1821+ is aimed at IT enthusiast and SMB customers looking for a powerful and scalable storage solution, its business-grade backup solutions keep users safe and protected from potential data loss, while major improvements to compute capabilities and throughput means workloads are finished faster than ever before.
Storage that fits your needs
Make the most of high-performance networking and file access without taking up unnecessary space. DS1821+ comes equipped with 8 bays and can scale up to 18 bays with 2 DX517 expansion units as your data needs grow.
The performance you need
Reduce transfer times with the DS1821+, designed to accelerate your workloads. Easily add faster networking and NVMe drives to further boost performance.
  • Accelerated performance
    177% higher 4K random read IOPS and 76% faster sequential write speeds compared to its predecessor.
  • Maximize performance
    Turbocharge HDD arrays by 20x or more without occupying drive bays using dual built-in M.2 slots for NVMe SSD cache.
  • Expansion made easy
    Scale-up on-demand to 18 drives with two DX517 expansion units.
  • Includes everything to protect your data
    Back up critical data to and from public clouds, Windows PCs and servers, virtual machines, and data on the NAS with Synology Active Backup suite, Hyper Backup, and Snapshot Replication.
  • Ready for 10GbE
    Add in a 10GbE SFP+ or RJ-45 NIC to instantly increase network bandwidth based on your existing infrastructure.
Synology Disk Station DS1821+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 8 (max)
34.3 cm x 24.3 cm x 16.6 cm
6 kg ()
AMD Ryzen Embedded V1500B 2.2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
RAM
4 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows 7 or later, Apple MacOS X 10.11 or later
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
34.3 cm
24.3 cm
16.6 cm
6 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 32 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, FTP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, VPN support, LDAP support, WOL, Syslog support, E-mail alert, High Availability, video server, web server, backup server, file sharing, anti-malware protection, TFTP support, ACL support, SSH support, iTunes server, Samba support, FTP server, surveillance station, PXE support, Apple Time Machine compatible, cloud backup, VPN Server, SFTP client, anti-virus protection, DLNA support
Encryption Algorithm
AES-NI
DLNA CERTIFIED
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 x PCI Express 3.0 x8 , 2 (total) / 2 (free) x M.2 2280
4 x USB 3.2 Gen 1 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA
2 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, hardware encryption
Security Slot Type
Kensington security slot
FCC Class B certified, RoHS, BSMI Class B
Hard drive security key, accessory pack
Internal power supply
Software Included
Drivers & Utilities
Limited warranty - 3 years
5 - 95% (non-condensing)
Hard Drives
G2Y2 Synology HAT5300-12T 12TB 3.5" SATA HDD In Stock £429.27
Interface: Ethernet
Capacity: 0GB
Type: 8-Bay
Interface: Gigabit Ethernet
Interface: Fast Ethernet
Brand: Synology
Price Range Ex VAT: £750 - £1000
