Synology DS1819+ 8 Bay NAS - Diskless
Quicklinx: DZPLWS00 Mfr#: DS1819+
  • Atom
DS1819+ is an 8-bay desktop NAS providing superior performance with great expandability, allowing for seamless expansion and upgradability to satisfy your growing business needs.
  • Robust security
    Equipped with AES-NI encryption algorithm and a Kensington security slot, the Synology Disk Station DS1819+ ensures your data is protected with advanced encryption and physical security options.
  • High-capacity storage
    With support for 8 hot-swap drive bays, accommodating both 2.5" and 3.5" drives, this NAS server provides flexible and scalable storage options, making it ideal for growing business needs.
  • Powerful performance
    Powered by a quad-core Intel Atom processor with a clock speed of 2.1 GHz and DDR4 SDRAM, the DS1819+ delivers efficient and reliable performance for handling demanding data management tasks.
  • Versatile connectivity
    Featuring four Gigabit Ethernet ports, two eSATA ports, and support for numerous network protocols, the DS1819+ offers versatile connectivity options for a wide range of networking requirements.
  • Comprehensive surveillance solution
    Supporting up to 40 IP cameras, the DS1819+ serves as a robust surveillance station, providing a scalable solution for your security monitoring needs.
Synology Disk Station DS1819+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
80 TB
0 (installed) / 8 (max)
34.3 cm x 24.3 cm x 16.6 cm
6 kg ()
1 x Intel Atom C3538 2.1 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
40
RAM
4 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows 7 or later, Apple MacOS X 10.11 or later
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
80 TB
34.3 cm
24.3 cm
16.6 cm
6 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 32 GB (supported) - DDR4
Dual channel memory architecture
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, FTP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, VPN support, LDAP support, WOL, Syslog support, E-mail alert, High Availability, video server, web server, backup server, file sharing, anti-malware protection, TFTP support, ACL support, SSH support, iTunes server, Samba support, FTP server, surveillance station, PXE support, Apple Time Machine compatible, cloud backup, VPN Server, SFTP client, anti-virus protection, DLNA support
Encryption Algorithm
AES-NI
DLNA CERTIFIED
Security DVR
40
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 x PCI Express 3.0 x8
4 x USB 3.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA
2 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, hardware encryption
Security Slot Type
FCC Class B certified, RoHS, BSMI Class B
Internal power supply
Software Included
Drivers & Utilities
Limited warranty - 3 years
5 - 95% (non-condensing)
