Synology DS1817 8 Bay Desktop NAS
Quicklinx: D886WS00 Mfr#: DS1817
DS1817 is a powerful, scalable 8-bay NAS delivering outstanding data transfer rates. With built-in dual 10GbE LAN ports in addition to dual Gigabit ports, DS1817 supports Link Aggregation and failover functions for maximum performance and service continuity.
  • Synchronize files across your devices
    Cloud Station Suite provides real-time data synchronization across all your devices, such as computers, mobile devices, and other Synology NAS whenever a file is modified.
  • Ultimate file management and sharing
    File Station is a web-based, fast and secure management tool built to allow easy, drag-and-drop operation without requiring any complex setup on Mac or PC. Advanced search and filtering tools allow for easy organization and sharing of files with just a link. Supports SMB, FTP, AFP, NFS, WebDAV, compatible with any environment.
  • Real-time collaboration on your private cloud
    Office is a collaboration package combining the convenience and usability of public clouds with the data privacy and security guaranteed by private clouds. It allows you to work seamlessly together on documents and spreadsheets in a protected environment.
  • Maximize system uptime with Synology High Availability (SHA)
    Enjoy a complete hardware and data redundancy solution with Synology High Availability (SHA) in case of unforeseen disasters. After joining two Synology NAS devices to form a high-availability cluster, the NAS acting as the active server will handle all data operations and services, while cloning the entire system to the passive standby server.
Synology Disk Station DS1817 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Max Supported Capacity
80 TB
0 (installed) / 8 (max)
34 cm x 23.3 cm x 15.7 cm
5.31 kg ()
1 x Annapurna Labs Alpine AL-314 1.7 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
IP Cameras Supported
30
RAM
4 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
3-year warranty
NAS server
Host Connectivity
Total Storage Capacity
0 GB
80 TB
34 cm
23.3 cm
15.7 cm
5.31 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 8 GB (supported) - DDR3L
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
TCP/IP, iSCSI, SMTP, FTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, Syslog support, E-mail alert, print server, firmware upgradable, MySQL server, web server, backup server, file sharing, RADIUS support, SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, surveillance station, DNS server, DLNA Media Server, eMule client, VPN Server
DLNA CERTIFIED, UPnP
Security DVR
30
Compression Format
MJPEG, H.264
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 2 x eSATA , 2 x Ethernet 10Gb - RJ-45
2 x network cable
Wake on LAN, built-in 2 cooling fans
RoHS
Internal power supply
Limited warranty - 3 years
5 °C
5 - 95%
