Synology DS1817+ (8GB)16TB-RED 8 Bay NAS
Quicklinx: CWG3WS00 Mfr#: DS1817+ (8GB)16TB-RED
  • Atom
Synology DiskStation DS1817+ is a 8-bay NAS powered by a quad-core CPU with AES-NI hardware encryption engine. Coming with quad 1GbE LAN ports, it can be installed with a 10GbE network interface card (NIC) or a dual M. 2 SSD adapter card, thereby enhancing network speeds or boosting performance with SSD cache.
Equipped with dual-channel memory and a PCIe slot, DS1817+ supports installing the dual M. 2 SSD adapter card, M2D17, or the 10GbE NIC, for high-IOPS system cache and ultra-fast data transmission respectively.
  • Centralized storage solution with outstanding performance
  • Supercharge your storage with speedy performance
  • Next-generation file system for effective data protection
    The Btrfs file system introduces the most advanced storage technologies to prevent data corruption and reduce maintenance overhead with optimized snapshots. It ensures high-level data integrity, while taking advantage of flexible, efficient data protection and recovery tools.
  • Ultimate file management and sharing
    The web-based File Station is a user-friendly management tool built to allow intuitive, drag-and-drop operation without any complex setup required on your Mac or PC. The advanced search and filtering tools enable easy organization and sharing that entails just a link. Compatible with SMB, FTP, AFP, NFS, and WebDAV, File Station suits all environments.
Synology Disk Station DS1817+ - NAS server - 16 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
16 TB
Max Supported Capacity
80 TB
8 (installed) / 8 (max)
34.3 cm x 24.3 cm x 16.6 cm
1 x Intel Atom C2538 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
8 x 2 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
8 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
16 TB
80 TB
34.3 cm
24.3 cm
16.6 cm
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
(supported) 8 GB (installed) / 16 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD
8 x 2 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, FTP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, VPN support, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, High Availability, video server, web server, backup server, file sharing, anti-malware protection, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, surveillance station, PXE support, Apple Time Machine compatible, cloud backup, VPN Server, SFTP client, anti-virus protection, DLNA support
Encryption Algorithm
SSL, TLS, AES-NI
DLNA CERTIFIED
Security DVR
40
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 x PCI Express 2.0 x8
4 x USB 3.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA
2 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, hardware encryption
Security Slot Type
Kensington security slot
FCC Class B certified, RoHS, BSMI Class B
Internal power supply
61.5 Watt
Power Consumption Stand by
31.6 Watt
Power Provided
250 Watt
Software Included
Drivers & Utilities, Synology Assistant
Limited warranty - 3 years
5 °C
5 - 95%
