Featuring a quad-core processor, hardware encryption engine, and flawless software integration, DS1815+ is a powerful, expandable 8-bay NAS server that delivers outstanding speed and accelerated data encryption. Easily scalable, the DS1815+ can be equipped with up to 6GB of DDR3 RAM and host up to 108TB of raw capacity with two Synology DX513 units.
Contains the WD Red Pro HDD's NAS optimised for 19" rack mount solutions with multi Axis shock sensors, vibration protection & dual actuators. With 5 years warranty
Quad-core CPU for blazing-fast performance
DS1815+ is powered by a quad-core CPU running at 2.4 GHz. Combined with 2 GB of DDR3 RAM (expandable to 6GB), it delivers blazing-fast performance over 450 MB/s reading and 420 MB/s writing. That much power makes it easy for DS1815+ to multitask and provide consistently high throughput to all connected clients. -
Fast encrypted data transmission with AES-NI
Encrypting data is essential to a healthy security policy. Equipped with a dedicated hardware encryption engine, DS1815+ is the ideal digital locker for sensitive data; files and folders are encrypted on the fly without any perceived performance loss. DS1815+ delivers encrypted data transmission speeds over 450 MB/s reading and 190 MB/s writing. -
Quad LAN ports for failover and link aggregation support
Equipped with four Ethernet ports featuring failover and link aggregation support, DS1815+ ensures continual network uptime even if LAN connection malfunction occurs on one port, reducing the chance of service disruption and costly downtime. Link aggregation improves connection speeds beyond the limits of a single network cable or port. -
Robust scalability 48 TB
As your data storage needs grow, DS1815+ can be connected to dedicated DX513 expansion units2 for additional storage on the fly, growing capacity with minimal effort. With two DX513 expansion units connected through specially designed eSATA connectors, raw capacity can be as high as 48 TB. -
Easy installation, hassle-free maintenance
Easy installation and hot-swappable hard drive support ensures easy maintenance and continuous service uptime should a hard drive need replacement. In addition, DS1815+ incorporates a passive cooling design to reduce dependency on the dedicated processor cooling fan, thus mitigating any critical point of failure. When the system detects a fan failure, the built-in redundancy mechanism ensures continuous operation until the replacement fan arrives. -
USB 3.0 and eSATA ensure speedy transfers to external storage
DS1815+ boasts USB 3.0 and eSATA ports to connect to various kinds of external storage devices, while ensuring fast and efficient file transfer speeds. Support for USB 3.0 offers transfer speeds of 5 Gbps (about 10 times faster than USB 2.0), meaning it takes less time to transfer data to external hard drives, while also consuming less power. -
Award winning OS - diskStation manager
Synology DiskStation Manager (DSM) is a sleek, browser-based operating system running on every DiskStation and RackStation, which makes managing your Synology NAS a breeze. Featuring an intuitive user interface, DSM makes accessing and sharing your data smarter and simpler. Synology's package center lets you download and install useful add-on packages designed specifically for individual or business needs, meaning you can enjoy more entertainment in your life or better productivity at work. -
Seamless storage solution for virtualization environments
DS1815+ provides seamless storage solutions for virtualization environments, including VMware, Citrix, and Microsoft Hyper-V. With VMware vSphere 5 & VAAI integration, DS1815+ helps offload specific storage operations and optimizes computation power in VMware environments. Windows ODX support speeds up data manipulation as the data transfer is offloaded. iSCSI also lets SMB users consolidate storage into data center storage arrays while providing hosts with the illusion of locally-attached disks. -
Fit into business environments easily
With the support of Windows AD, LDAP, and Domain Trust, DS1815+ enables seamless account integration. The User Home feature can automatically create a "home" folder for every user account to minimize the administrator's effort in repeatedly creating "home" folders for all accounts. Windows ACL support on DS1815+ allows IT administrators to fine tune access controls and set up privileges to files and folders on DS1815+ through the familiar Windows user interface. With compatibility for major protocols, DS1815+ can eliminate server configuration overhead and enhance IT administrators' efficiency. -
Optimize storage management
With Synology's storage manager, DS1815+ allows for flexible storage deployment and utilization. You can optimize RAID configuration with Synology Hybrid RAID (SHR) while providing redundant data protection. Other features such as multiple volumes on single RAID and Global Hot Spare also greatly enhance management efficiency and fit deployment of any kind. -
Synology CMS (Central Management System)
For enterprises with more than one Synology NAS server, CMS offers the flexibility and convenience for IT administrators to manage all of them from a single point of entry. Through a simple interface, you can obtain a clear overview on resource consumption and logs, helping you identify any issue right away. With group policies, CMS can do much more for your daily tasks. Once a NAS joins a group, it will automatically adopt its rules and behave as intended, without extra configuration. -
All-in-one server
DS1815+ can replace several pieces of network hardware and serve as your multi-function server. Directory server provides LDAP service, while DNS and DHCP packages allow you to host a domain name server and automate network IP assignment at no extra cost. With only one DS1815+, you can do more than you imagine - host up to 30 websites with web station, safeguard the office environments with Surveillance Station, send and receive mail using your own email domain with mail station, share printing capability with Printer Server, make DS1815+ act as a VPN server to access company's resources remotely, and more. DS1815+ helps your company gain a competitive edge. -
Ensuring business continuity
Uninterrupted availability is a critical goal for all businesses. DS1815+ supports Synology High Availability (SHA) technology which combines an active and passive server into one cluster, the former always mirrored to the latter. The heartbeat mechanism detects regular "heartbeats" between the two servers. If the main server encounters unexpected downtime, the passive server immediately takes over. With multiple LAN ports, DS1815+ also ensures redundancy in the event of unexpected network failure. -
Effective backup solution
Synology DS1815+ can serve as a centralized backup target. PC users can back up their data to the DS1815+ using Windows backup, while Mac OS X users enjoy native Apple time machine integration. You can also back up data and applications from your DS1815+ to another DiskStation, rsync servers, external drives, or even Amazon S3 and Glacier cloud service. "Backup & Replication" allows you to schedule backup tasks and restore the server to any particular point in time, while minimizing storage consumption and processing time by saving only the specific data block that has been changed between versions. -
Secure your data
DS1815+ provides share-level AES 256-bit encryption to block off unauthorized access attempts. Once you create and encrypt a shared folder, people without the encryption key will not be able to use the encrypted data even if they remove the hard drives from your DS1815+ and mount it on their device. 2-Step verification gives an extra layer of protection as 6-digit one-time code sending to your mobile device is required for login. In addition, DS1815+ provides other security add-ons, such as IP block & allow list, Antivirus packages, firewall, and Dos attack prevention. These enhancements ensures a secure DSM environment.
- Synology Disk Station DS1815+ - NAS server - 48 TB - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 48 TB
- Max Supported Capacity
- 48 TB
- Installed Devices / Modules Qty
- 8 (installed) / 8 (max)
- 34 cm x 23.3 cm x 15.7 cm
- 5.29 kg ()
- Processor
- 1 x Intel Atom C2538 2.4 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 8 x 6 TB
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 40
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- TAA Compliant
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 48 TB
- 48 TB
- 34 cm
- 23.3 cm
- 15.7 cm
- 5.29 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 2 GB (installed) / 6 GB (supported) - DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD
- Capacity
- 8 x 6 TB
- Data Link Protocol
- TCP/IP, iSCSI, SMTP, FTP, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, LDAP support, Syslog support, E-mail alert, print server, firmware upgradable, MySQL server, web server, backup server, file sharing, RADIUS support, SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, surveillance station, DNS server, DLNA Media Server, eMule client, VPN Server
- DLNA CERTIFIED, UPnP
Security DVR
- 40
- Expansion Bays
- 8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x eSATA
- Cables Included
- 2 x network cable
- Wake on LAN, built-in 2 cooling fans
- FCC Class B certified, RoHS, BSMI Class B
- TAA Compliant
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 250 Watt
- Software Included
- Synology Assistant, Synology Data Replicator
- OS Required
- TAA Compliant
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 5 - 95%
