Synology DiskStation DS1812+ offers a high-performance, scalable, and full-featured network attached storage solution that meets the needs of small and medium-sized businesses that require an efficient way to centralize data protection, simplify data management, and rapidly scale storage capacity with minimal time spent on setup and management.
With the link aggregation enabled, Synology DS1812+ delivers an average 194.48 MB/second writing speed under RAID 5 configuration in a Windows environment, and 202.20 MB/second reading. Coming with USB 3.0 support which offers transmission speeds of up to 5 Gbps, namely 10 times faster than USB 2.0, DS1812+ takes less time for data transfer for external hard drives and consumes less power. Synology DS1812+ brings you the high performance that your data-intensive applications demand for a storage system, and offers the ability to scale the storage capacity.
Reliable functioning of commercial systems is of paramount concern to business users who depend on these servers every day. Synology DS1812+ is now introduced with the fanless CPU heatsink to prevent the single point of failure. With the CPU passive cooling technology, Synology DS1812+ achieves the high reliability system design. When one of your system fans malfunctions, the built-in system fan redundancy mechanism can extend service uptime by keeping the remaining fan running and your DS1812+ performing basic operations until the replacement fan arrives. The 2 LAN with failover support and hot-swappable drives will ensure continual service uptime should the drives need replacement or the unexpected LAN failure occurs.
High performance, high data availability
With the link aggregation enabled, Synology DS1812+ delivers an average 194.48 MB/second writing speed under RAID 5 configuration in a Windows environment, and 202.20 MB/second reading. Coming with USB 3.0 support which offers transmission speeds of up to 5 Gbps, namely 10 times faster than USB 2.0, DS1812+ takes less time for data transfer for external hard drives and consumes less power. Synology DS1812+ brings you the high performance that your data-intensive applications demand for a storage system, and offers the ability to scale the storage capacity. -
High reliability
Reliable functioning of commercial systems is of paramount concern to business users who depend on these servers every day. Synology DS1812+ is now introduced with the fanless CPU heatsink to prevent the single point of failure. With the CPU passive cooling technology, Synology DS1812+ achieves the high reliability system design. When one of your system fans malfunctions, the built-in system fan redundancy mechanism can extend service uptime by keeping the remaining fan running and your DS1812+ performing basic operations until the replacement fan arrives. The 2 LAN with failover support and hot-swappable drives will ensure continual service uptime should the drives need replacement or the unexpected LAN failure occurs. -
Unified-architecture and virtualization ready
Synology DS1812+ runs on the novel operating system, Synology DiskStation Manager (DSM), which integrates file-level and block-level storage in one unified storage system. iSCSI is also supported as the ideal alternative to SAN solution for business. Affordable and cost-effective iSCSI allows large scale business to consolidate storage into data center storage arrays while providing hosts with the illusion of locally-attached disks. With the iSCSI support, DS1812+ provides a seamless storage solution for virtualization servers. Thin Provisioning is available for file-level iSCSI, enabling administrators to oversubscribe provision and then grow storage space as needed in safety. With thin provisioning, users are able to maximize the storage utilization to reduce the total cost of ownership for the storage system. -
Energy efficient design
Synology DiskStation are designed and developed with energy efficiency in mind. Compared with the average PC counterparts, Synology DS1812+ consumes only 50.6 watts in operation. The support of wake on LAN, scheduled power on/off and hard drive hibernation can further reduce power consumption and operation cost.
- Synology Disk Station DS1812+ - NAS server - 24 TB - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 24 TB
- Max Supported Capacity
- 32 TB
- Installed Devices / Modules Qty
- 8 (installed) / 8 (max)
- 34 cm x 23.3 cm x 15.7 cm
- 5.2 kg ()
- Processor
- 1 x 2.13 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
- Hard Drive
- 8 x 3 TB SATA 3Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
- RAM
- 1 GB
- Power
- AC 120/230 V (50 - 60 Hz)
- System Requirements
- Microsoft Windows 2000 or later, Apple MacOS X 10.3.x or later, Ubuntu 9.04 or later
- TAA Compliant
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 24 TB
- 32 TB
- 34 cm
- 23.3 cm
- 15.7 cm
- 5.2 kg ()
- Built-in Devices
- Print server
Processor / Memory
- Processors Installed
- 1 x 2.13 GHz
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 1 GB (installed) / 3 GB (supported)
Storage Controller
- RAID - internal
- Interface Type
- SATA 3Gb/s
- Data Transfer Rate
- 300 MBps
- Max Storage Devices Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
- HDD - hot-swap - 2.5" / 3.5" shared
- Capacity
- 8 x 3 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- PPPoE, FTP, POP3, DDNS
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS
- Network Services Compatibility
- Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
- Firewall protection, wake on LAN (WOL), E-mail alert, print server, IPv6 support, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, Advanced Data Streaming (ADS), SSH support, iTunes server, FTP server, SMS alert, UPnP Media Server, surveillance station
- UPnP
- Expansion Bays
- 8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 4 x USB 2.0 - Type A , 2 x eSATA 3Gb/s , 2 x Ethernet 1000Base-T - RJ-45 , 2 x SuperSpeed USB 3.0
- Cables Included
- 2 x network cable - 2 m
- FCC Class B certified, RoHS, BSMI Class B
- TAA Compliant
- Power Device
- External power adapter
- Voltage Required
- 71.5 Watt
- Software Included
- Synology Assistant, Synology Data Replicator
- OS Required
- TAA Compliant
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 23.1 dBA
